Tenon failure
Tenon failure
Steven Antonucci
Tenon failure
steve antonucci
>I've had this burl laying on the woodpile for a while. Tonight, I fired up the chainsaw and processed it into a bunch of small pieces and one large one. I was going for a Southwestern shape, and I saw a small soft spot on the outside. I figured that it would either turn out, or I'd have a hole. The whole time I was shaping the outside, I noticed a slight wobble that wouldn't go away.
I had a good surface despite the wobble, and had just started hollowing when I had a minor catch. The next thing I see is my pot jammed between the toolresat and the ways.
Tenon failure.
Now, this tenon was at least 5" across, and it sheared in a split second. Why? Because dirt has no strength at all in shear. The entire thing was marginally still wood, and I was surprised that I had gotten that far without the thing failing. I stuck an awl clear through it.
So tomorrow, next day, whenever, I'll bandsaw this into 4-6 smaller blocks and wax them for some day. Life it too short to turn crappy wood :-)
Steven
Re: Tenon failure
Steven Antonucci
tenon close up
steve antonucci
Re: Tenon failure
Steven Antonucci
top of the pot
steve antonucci
Re: Tenon failure
Re: top of the pot
Barry Turner
>I've glued those failed tenons back on with Titebond...........
Re: Tenon failure
Steven Antonucci
No amount of glue would save this one
steve antonucci
>The tenon is made of dirt. The hole on the outside was soft, and it was dirt after that. I turned it down 2" after the photo with 2 "cuts"- and there was nothing but cherry colored dirt on the ways.
I really thought about it, but this one is now 4 smaller forms in the next day or so...
Steven
Re: Tenon failure
make some art
>Drill it out, embed rebar to hold the pieces together and let it stick out the top and bottom, spray it with something, and call it art.
Re: Tenon failure
Steven Antonucci
That would be, um, creative... :-)
steve antonucci
>I wonder if the other burl will be the same type of disappointment. I'm going to get about 6 little pieces out of this one, but I really had my heart set on the one bigger one...
Maybe the other burl will have a rebar embedded in it and I can design around it?
Steven
Re: Tenon failure
Dick Hines
Re: That would be, um, creative... :-)
Dick Hines
>I have had this happen before. I try not to turn the piece down to finished thichness until I have hollowed out the inside. Just leave the bottom a tad thick and coat with thin CA. Then after you have hollowed out the piece turn the bottom to finial shape.
I have had good luck doing this." Most of the time"
