THE WOODRAT IS BACK!
Source for Nichrome wire
stacey s
>Where is a good source for nichrome wire. my interest in woodburning was rekindled again this weekend at the Southern States Symposium. After Seeing Graeme Priddles demonstrations this weekend I am going to build a woodburner. I am trying to get a source for the wire first since I am going to have to order it this will give me time to build the rest of the unit while waiting on the wire.
Stacey
Re: Source for Nichrome wire
Randy G
>I ordered a great spool of it on Ebay, now have more than I'll ever need.
Allen Neighbors
>I know nothing about Nichrome wire, but I sure am interested in the home built woodburner. Any chance of you doing a work-in-progress tutorial on it?
Just asking.... :)
stacey s
>Sure no problem. Graeme Priddle described it as follows:
hook 600amp dimmer switch to a power cord(input side of the switch) The output side of the switch should be wired to a 110v outlet. both items should fit into a double gang electrical box. Now you can plug the cord feeding the dimmer switch into the wall and you can plug a battery charger into the outlet connected to the dimmer switch. The only other thing to do is to build a burning pen to connect to the battery charger. This will allow you to continue to use the battery charger to charge car batteries. I will try and take some pictures to better explain as soon as I get started. I will also do some pictures of the pen when I make it. I just looked at it and don't have the exact procedure yet.
Stacey
ps
>some other recycled sources:
old popcorn poppers with coil wire
old hairdryers
old toasters
old space heaters
remember it's cool to be green :>)
Re: ps
stacey s
>thanks for the reply about the recycled sources. As to Treeline I was hoping to find it in larger quantities, I quick search on google yielded a few places with 50foot reels for $20, but I was hoping for recomendations to someplace where someone has purchase from before.
Again thanks for the idea of using recycled sources.
Stacey
Re: ps
Phil Powell
>I have 200 hundred feet of two different gauges. Let me know how much you may
want and I'll send you some.........free
Great! I'll be watching!! Thanks!
Allen Neighbors
How about wire from a wire welder?
Allen Neighbors
>Would it get too hot and melt, or would it not get hot enough? I have some that is about the same gauge as the lettering on my pieces... which are burned in with the point of a cheap woodburner.
Very generous Phil
Dave Peebles Lyons, Ohio!
>I love this place :)
Dave
Re: How about wire from a wire welder?
jim miles- Charlotte
>Try a junk toaster or hair dryer. Heating element is usually nichrome
Re: 600 amp???!!!!
Al Crandall -NW of Indy-
Probably 600 Watt :-)
clem Wixted
Re: 600 amp???!!!!
stacey s
>You are correct typo on my part I wasn't thinking. Electrical is not my stong point but it clicked when I saw your message that I put the wrong thing in.
Stacey
Re: ps
stacey s
>Thanks phil I will send you an email.
Stacey
Scott Greaves in Blackfoot Idaho
>I second the old toaster suggestion! When I was younger I was into archery, and I made all my own arrows. For the fletching (the feather part) I used real feathers that needed to be trimmed to shape after gluing to the arrow shaft. I made a jig out of nichrome wire in the shape I wanted the fletchings, and burned off the excess. I just bought an old junk toaster and salvaged the wire from that!
Good Luck!
Scott.
Allen Neighbors
>I have wire from a wire welder. I don't have an old toaster/heater thingie. :) Just thought I might save some fuel by not having to drive to the metal pile at the dump. I'm going to try the welding wire.
Dennis in Southern Oregon
>Stacey, I bought some about a year ago for the same purpose from MPak Systems Online. I received prompt service. Their url is http://mpaksys.homestead.com/nichrome.html.
Dennis
building a pyrography machine *LINK*
>You might find this useful:
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=82043
pyrography machine thread
Stacey S
>Thanks Dennis for the link. I will have to look at then when I get home. The proxy at work has that link blocked.
Stacey
Mike in Suwanee
>I must have been in the same Priddle session with you. I am also interested in building one. Would be interested in details on source and model for the 10-15 amp battery charger with no electronics he mentioned.
Stacey S
>I have a cheap one that my mother bought a few years ago that I suspect will work. Probably the best source would be to go to harbor freight and get the cheapest battery charger they have.
