Dyed box elder box....
Mike Stafford
Mike Stafford
>I had this piece of box elder in a square in my scrap bin and decided to do something with it. I rounded it up and noticed that the wood was cut with the grain about 30 degrees from vertical. Now usually for stability I prefer the grain to be running from top to bottom.
I decided to go ahead and turn a box from it. After doing so the wood was plain and nondescript I decided to dye it. I did so following some advice I received regarding getting an even color over the box's entirety despite the tendency for the end grain to soak up the dye more readily. I wet the wood with alcohol and applied the dye and immediately took a paper towel that was wet with alcohol and used it to blot up the excess dye and try to achieve a uniform color.
Whether I succeeded or not is for you to judge. The box is 3" tall and 3 1/2" in diameter. Comments and criticisms appreciated...
Re: Dyed box elder box....
Greg Haugen
>I'd say you succeeded! Could have been dull white and no character. The dye added a warm tone to it and brought out some very nice "interest" to the grain. Well done!
I often used Box Elder as jam chuck/waste block material unless it's exceptional.
Greg
double winner!
GaryG in MD
>Mike,
I think you're on to something here. The biased grain is wonderful. That's a real eye opener. I think this is a "direction" worth more exploration. This might be worth some discussion in the SIG at Richmond.
The color is great. What color(s) of dye did you use?
...Gary
Mike Stafford
Re: double winner!
Mike Stafford
>Thank you, Gary, I only used one color of dye, scarlet. There are several applications to get this rich color. I like the red as the wood seems to take on the appearance of bloodwood.
By all means bring up the topic at the Box SIN and we will see who salutes...
Dick Hines
Dick Hines
>JACK POT Mike!!! One day I am going to take the time and learn how to do boxs 1/2 as good as yours.
tm
>nice
