Chainsaw Oil
Chainsaw Oil
Chainsaw Oil
Clem Wixted
>While we are having some good discussion regarding gasoline for chainsaws, I have some questions about chainsaw oil for mixing with the gasoline.
Some chainsaw manufacturers make, or package, their own oil for mixing with gasoline. Some oils are generic for mixing with the gasoline in a proportion recommended by the chainsaw manufacturer.
Here's my questions. I have a few gallons of 2 cycle OUTBOARD motor oil. What makes the oil OUTBOARD specific? Can it be used in non water cooled 2 cycle engines? Does the water cooled outboard motor require different oil. How different is OUTBOARD oil from 2 cycle oil?
Thanks,
Clem
Re: Chainsaw Oil
Re: Chainsaw Oil
Doug Turner
>I have a gallon of outboard motor oil (50:1 mix ratio) and I have used it in my Husky chain saw, lawn mower, and weed eater for several years without incident.
Re: Chainsaw Oil
Thanks, Doug
Clem Wixted
>That's what I was hoping to hear.
I guess there are no oil engineers on this forum. I wonder why the oil has an outboard designation. Maybe it's lighter to keep the boat from sinking :-)
Clem
Re: Chainsaw Oil
Jim DeLaney, Austintown, Ohio
Re: Thanks, Doug
>Years ago, I was told that the outboard oil was a special 'low ash' formula, made to compensate for the lower running temperatures of an outboard (which had - has? - no thermostat in the cooling system), as opposed to an air cooled engine.
Don't know if that was true - or still is - or not.
Jim D.
Re: Chainsaw Oil
I Just Did Some Internet Research *LINK*
Clem Wixted
>Jim, Looks like you are right.
I checked an Ultralight Aircraft web site about oil in their aircraft. There apparently are some technical differences in air cooled and water cooled oils. For occasional use it may not make any difference which oil is used in a chainsaw but for continuous use it probably makes sense to use an oil designed for the engine.
Here is a link to the article:
Air Cooled vs Water Cooled 2 Cycle Oil
Re: Chainsaw Oil
Re: Chainsaw Oil
Russ Fairfield
>The simple answer is that there are only two types of 2-cycle oil, and the difference is whether they are used in air-cooled or water-cooled engines, and the 2 types are for operating at different temperatures. All other differences are only the container and the price.
However, the differences can be more complicated than that. Some oils are more biodegradeable than other, some are petroleum products, and some are synthetic oils.
As to switching the oils, there can be problems over time and a lot of use. The air-cooled oil operates at higher temps, and using it in a water-cooled engine will tend to cause excessive deposits. A water-cooled (outboard) oil used in an air-cooled engine will tend to cause scuffing from inadequate lubrication. I don't think most people would ever see the difference unless they operated the engine for a lot of hours.
