Gambel Oak HF
Curt Fuller
>Nothing spectacular here, this is just a small hollow form. But I thought the wood was nice, especially for Oak. This is Gambel Oak from my backyard, turned with the pith in the center, 6.5" x 3.5" with danish oil finish
Gambel Oak HF
Curt Fuller
can't display the photo
Re: Gambel Oak HF
Curt Fuller
>Try this.
Re: Gambel Oak HF
>Much better! I love the look of turned white oak - the way you turned the pith on the center is especially nice since the radial ray pattern draws the eye to the center.
Re: Gambel Oak HF
charlie belden
>Looks like the main pith runs down the center of the piece. That normally results in cracks propagating from the pith in the bottom of the piece.
Was this roughed green and finished when dry or almost dry or turned dry?
Any special things you did to avoid the Pith In Cracking Problem?
I really like the way the growth rings cascade down the top of the piece. Still can't decide if the knot on the side is a focal point - or a distraction.
Nice piece either way.
charlie belden
Re: Gambel Oak HF
Brad Vietje
>Hey Curt,
Love the form and the orientation. In my experience the way to combat cracks when turning on the pith is to go for a uniformly thin piece when green. Efforts to dry a piece that's too thick can lead to cracks. I also use some CA on the pith, and have better luck with a branch or knot about where the foot will be to add some curly grain structure.
Breaking the "rules" can be a challenge -- and fun!
Safe spinning,
Brad Vietje
Newbury, VT
Re: Gambel Oak HF
GaryG in MD
>Curt,
I agree with the comments about the rays and rings, etc. That's a very nice piece. Keeping it from cracking is the challenge. This might be a good situation for the microwave.
Hope to see some more like this.
...Gary
Re: Gambel Oak HF
Curt Fuller
>Thanks everyone.
This particular piece of wood has been cut since a last winter, 2006-7, and was left in about a 10' length since then. So it's pretty dry to start with and then it's also turned to a pretty even 1/4" thickness. But with Oak and with center pith I still wanted to take the picture before it had a chance to self destruct.
This makes me ask...
Steven Kubien
>...those of you into hollow forms, do you usually orient the grain along the long axis or the same way one typically does a bowl? I have only just started playing with hollowing. Mostly small branch-wood and forms in the 3-4" diameter, 4-6" tall range. I mostly turn bowls and when I see a nice log, that is where my bias lies...to cut it into bowl blanks. Should I be looking to sacrifice some bowl stock?
Curt, that is a very nice piece. If any white oak comes my way, I will try something like what you have done. Well done.
Steve Kubien
Ajax, Ontario
Re: This makes me ask...
Dick Hines
>I have turned hollow forms both ways. If I have a thick blank and it does not have the pith in I will look at the grain to see what looks the best in my eye. If the pith is still in the blank I will turn it cross grain. Right now I am into turning HF's from BLM burl. It does not make much difference with burl. Grain runs all over the place.
Curt Fuller
>I've found it easier to hollow if the grain runs parallel to the ways. I usually drill a hole, about 3/4" dia., both for a starter and a depth guage. Everything works better that way without the tearout and sanding problems that go with turning across the grain. But some pieces of wood look much better if you go across the grain. This piece of English Walnut crotch would have lost most of it to shavings if it were turned parallel to the lathe instead across the grain.
Thanks
Steven Kubien
