Re: Old Report
Jesper, Denmark
>Hi Barbara,
The petroleum refining industry has not changed that much in the last 4 years. Particularly not in the USA, where no new refinery has been built for many years. I even think the last grass roots refinery wad the then Mobil refinery in Kankakee, IL, when I lived there - in the 70 and 80's.
All that has happened since has been quality improvements in terms of reducing sulfur and getting rid of first tetraethyl lead and since MTBE and adding ethanol. I am not aware of "the fuel filter problem" it does not exist here in Europe. Probably the higher solvency of the added ethanol is cleaning out crud in the tank, depositing this in the filter.
It does not have any effect on the basic question: Higher octane gas ONLY helps if the engine pings. If it does not, then "High Test" is no better quality than regular.
Pinging is not usually a problem with small engines. If you check the engine specifications, it probably has a compression ratio around 9 - absolutely no problem with regular gas.
Incidentally, our gas is no better quality, although we end up paying $8/gallon. One the other hand, Diesel quality is very good at <7/gallon, so as it has more energy per gallon than gas and the engines are more efficient, that is what people now buy.
