Re: Stihl won't start
Peter Teubel
>Sounds like you have a clogged carb due to old UN-stabilized gas.
#1) Get some gas stabilizer and add it to your gas can NOW. That way you will never forget when you fill the saw.
Here's what I would do:
Remove the spark plug and spray some starting fluid directly in the cylinder.
Remove the air filter, open the choke, and spray starting fluid down the carb throat. Don't get it drippy wet with fluid otherwise a backfire could ignite the spillover.
Try to start it with the choke OFF and the throttle in the start/high-idle position. If it tries to fire, apply full choke and continue starting.
If you smell gasoline, you've probably flooded it. The way to clear a flooded gas engine is to try starting it with NO choke and the throttle WIDE open. This is always "fun" with a chainsaw. Remove the bar and chain if you are not comfortable with this technique or set the chain brake.
From my experience, every two-stroke engine develops their own unique starting procedure. For example, both my MS170s (from dead cold) require 5 pulls at full choke, then 2 pulls at fast idle. Every time. Without fail. I can set my watch by them. My MS390, 4 pulls at full choke, then one at fast idle. My MS180E starts instantly when I pull the trigger (electric) ;)
