Re: hoping for some tips on using an epoxy finish *LINK*
Brian Hahn in SW Wisconsin
>For woods that are naturally oily, use acetone or lacquer thinner to remove the surface oil first. I've never worked with ebony so I don't know if this applies.
Slow cure epoxies are generally more waterproof. A marine epoxy like System 3 is below-the-waterline waterproof with three coats. I've used three coats of both the hardware store 30-minute clear epoxy and the System 3 epoxy on the insides of vases and they both were waterproof - our secretary tested one - it had water and flowers in it continuously for 3 months.
Apply several "thin" coats with a disposable brush. Subsequent coatings will bond to the previous coat if applied within a day or two. Sanding is optional and only to level the surface.
Epoxy is 100% solids, so the finish will end up rather thick, even with thin coats.
System 3 has a good brochure on waterproofing with epoxy. The link below is to a pdf file of the bouchure.
>There are some techniques you can use for success.
Warm the wood before applying the epoxy. The heat will thin the epoxy so it can be absorbed deeper into the wood. Also the heat will cause fewer molecules of air in the wood so that while the wood cools and the air molecules shrink the epoxy will be "sucked" into the wood.
Apply the second coat before the first coat of epoxy has cured. If you can do this then the second coat will have a molecular bond with the first coat. If you wait till the first coat has cured then you should scuff sand the first coat so the second coat will have a good mechanical bond with the first coat.
Watch what you are doing with the first coat and make sure the wood is completely covered. Some parts of the wood will absorb epoxy faster than other parts.
The epoxy will flow long after you think it should stop flowing. If you can rotate the turning as the epoxy cures you will be less likely to have puddling of the epoxy. It is next to impossible to prevent puddling without the rotation.
If you can heat the turning during the last couple of hours of cure you will have a very good tough cure.
Is this a lot of work. Yes it is. The chance of you getting it all right the first time is very unlikely. If you do this 4 or 5 times in a month you will be a LOT better at it.
