Colorwood Finish
Colorwood Finish
Colorwood Finish
elliott
>Does any one have suggestions on what to use to as a finish for high gloss on colorwood? Purchased the wood from Hut Products and turning pens with it.
Re: Colorwood Finish
Greg Haugen
>Sometimes with the dyed veneered woods like Dymondwood or Colorwood they can be so saturated with dyes, they're practically sealed already. In the past when I turned those products I used some of the friction polishes/waxes. If in-doubt call Hut and see what they'd recommend.
Not much help, I know.
Greg H.
elliott
>Found out from Hut that the best thing is to apply sanding sealer then use regular finish or huts crystal coat
Tommy Holmes
>After micro-mesh, buff with white diamond then back on the lathe for sanding sealer and friction wax. I was really pleased with the results of the buff when I tried this.
elliott
>what type of friction wax do you recommend to try
Tommy Holmes
>I have used Shellawax and and Mylands. I prefer Shellawax. It seems to leave a little more luster.
