tormek and a bowl gouge
woody in vt
>I just bought a tormek and sharpened my side ground bowl gouge using the proper jig according to the instructions that came with it. The tip is very sharp, but if I try to cut with the sides, it catches something fierce. Anybody have similar experiences and more importantly, what have I done and how do I fix it. As always, thank you in advance.
Re: tormek and a bowl gouge
Brad Vietje
Brad Vietje
>Hey Woody,
Were you experiencing catches before? If you are already familiar and at ease with a side-grind (Ellsworth, Irish, O'Donnell etc...) bowl gouge, then I'm unable to help.
If this grind is new to you, look into David Ellsworth's video on the use of his signature gouge. The other grinds are only slightly different, and the fundamental mechanics are the same.
BTW: where in VT ?
Safe spinning,
Brad Vietje
Newbury, VT
woody in vt
>The catches are new and are fairly violent in nature. Thanks for your reply. I live in Barre.
Charles Watson
>It sounds as if the side grind angle is now different than what you're use to, and that the tool presentation to the wood is wrong.
As previously mentioned, the Ellsworth video is an excellent resource for the proper use of the side grind gouge.
>I agree with the others. It's not the sharpness but how you handle the tool. You have to ride the bevel on the sides to keep it from catching. I teach people to set the bevel of the tool on the wood with the cutting edge rotated away from the wood. The rotate the handle until the cutting edge of the side grind starts to cut. Now you know exactly how it needs to be when doing this cut.
Darryl
>are you using the "Ellsworth" type swept back grind? the settings for that grind are one notch beyond the marks (i.e.6) a 2" projection and 65 degree settings. Check to see if you have a hook at or close to the tip. the edge of the grind should be smooth from the back to the tip. It is easy to get a hook on some of the gouges with the Tormek depending upon the gullet in the tool design and that will cause the catches you are speaking of. Check the grinds library and look at the picture of the "Ellsworth" or swept back grind.
Brad Vietje
Brad Vietje
>Woody,
Hey, we're practically neighbors ! I own a solar energy business in Groton, only about 17 miles away on RT 302. Newbury is 8 miles further east, basically near Wells River. I'm actually headed to Barre this afternoon for a solar hot water site visit, then on to Montpelier.
Once you get the grind/bevel just right on the Tormek, you won't want to take that much time to sharpen and maintain the edge very often (I sharpen or hone about 4 times while finishing a bowl), so you will find it a LOT faster to use a small diamond hone, then use the Tormek for re-shaping after maybe 50-100 swipes with the diamond hone. I use the small 3/4" by 2" ones mounted on a small handle from DMT -- you can get these at Spooner's in Montpelier. I have a 3-piece set, then I added a 9 micron extra-fine to that, and a round hone for inside the flute.
Feel free to give me a call if you want any help. My store is a local call for you: 584-4977. I use swept-back bowl gouges all the time, and have done a lot of teaching and demonstrating at local turning gatherings. You could also check out the tool grinds library here at W/C, and see how your grind compares. There are also two turning groups nearby: The Woodchuck Turners of Northern VT meet monthly in Burlington/Shelburne (3rd Thursdays, I think), and a newer group, the Twin State Turners, meet over near me in Ryegate on the 3rd Wednesday of each month. Also, one of the best turning instructors I know of, Richard Montague, lives nearby in Groton.
Call sometime, and we can get together and blast out a bowl!
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Woody -- Any Luck ?
Brad Vietje
>Woody,
Let me know if you're still having any trouble and/or if you want any assistance with the problem. There are so many ways of using a swept back bowl gouge that it can be pretty daunting -- and scary -- when it takes big bites you didn't mean to take.
Bad words can happen... New bad words no one ever of heard before have been invented this way -- DAMHIKT!
I'll be working out of state for a few days, and hope to do some turnin' this weekend -- feel free to call at the store (local): 584-4977, or at home (probably not local) 429-2154. My in-laws are in Barre, so we're probably headed over your way before mother's day.
Safe spinning,
Brad Vietje
Newbury, VT
