OT Water based Varnish for Floors
Steve in NC
>A bit off topic but I figured there is a good chance for experience in this group.
I have to refinish some oak floors this weekend. Would love to use water based poly for less odor and recoat times. Concerned about durability relative to oil based. Anyone have any experience with waterbased poly on floors.
Thanks
Steve
Re: OT Water based Varnish for Floors
Cyril Griesbach
>We're redoing our flooring but not hardwood. However, we're going to be putting in new oak base molding and as I can't get the Carver Tripp water based poly I used on the other oak doors and trim I went with the Min Was water base. The can does provide info on using this produce on floors and as I recall there is just a longer cure time recomended for going on floor. I suspect this longer time is because of wear because the actual cure time has to be the same.
Bill Howatt
>I haven't used it but I have seen various references where the cured water-based product is actually harder than the oil-based. That is cured not just dry to the touch.
Bill
Barbara Gill, Remlik VA
>We installed a wide plank white oak floor for a friend who wanted the oak to stay bright so we used a water based poly. I think it was at least 7 years ago. The floor looks almost as good today as when we put it in.
Rich Egan
>Steve:
I stripped down the maple floors in my son's room last year, and finished with a water-based poly. The floor came out better than I had hoped, and seems to hold up very well to scrapes from furniture. It dried quickly, and produced no odor. Purchase a quality product, and you should have similar results. Just get the floor as clean as you can before finishing.
Rich
That's true Bill
Steven Kubien
>A lot of the water-based floor coverings have a strong acrylic component to them that is supposed to make them harder.
Steve
jim miles- Charlotte
>I did my pine floors in 2 rooms last July. Happy with it so far.
It does seem to be thinner that oil based and requires more coats.
Use it...
keith zimmerman, Normal, IL
>It works very well and is harder than oil-based. Be aware that it looks milky when applied. It will clear when it cures.
As others have said, buy a quality product. MinWax is a good one.
keithz
