OT Digitizing 35mm slides
DickL
>Hey photography experts. I have a bunch of 35mm slides and would like to convert them to digital format. What is the best approach?
Thanks.
Re: OT Digitizing 35mm slides
keith zimmerman, Normal, IL
>Any scanner capable of scanning slides will work. A dedicated slide/film scanner is best, but rather pricy. There are several flatbed scanners with built-in slide/film attachments that do a decent job of scanning slides or film.
Epson, Canon, and HP are a few of the flatbed scanners that have models that will scan slides.
keithz
Bill Howatt
>I had about 2500 slides or so. Nothing for the art gallery just the usual vacation scenery, weddings, family events, etc. We went through them and after getting rid of the duds, duplicates, similars, the total got down to about 650.
I have a scanner with a slide copier feature. It would take me over a minute to dust, insert the slide, possibly preview, scan, store per slide.
I made this gizmo which attaches the camera via the tripod mounting screw hole. The camera was set to macro and tungsten lighting balance. I found the location to mount the camera by attempting to fill the frame as much as possible. The camera lens front was about 1/2" from the slide.
The curved part is a white plastic sign. I found there was a bit of light leakage so ended up draping an old black sock in the gap between the camera and slide mount.
About 10 seconds per slide to do the steps above.
The illumination was very even and I really could not tell the difference between the ones scanned by the scanner and the camera. I had a couple of pictures I zoomed in to a very high level of magnification to look at a detail and was amazed at how good it was.
With illumination picture
Bill Howatt
>Halogen worklight (150W) and 100W halogen desk lamp. The amount of light made little difference since the camera compensated for the light. I removed the wire guard on the worklight for this project just in case the shadows might be a problem.
To clarify about the light leakage cured with the black sock, the light caused a reflection from the silver end of the lens piece to project onto the slide and thus faintly show up on the image.
Bill
Justin Fields
>Depends on your definition of "bunch" and your budget. There are places that will do the entire job for you. Or you can buy/rent/borrow a scanner.
We went through about 40 carousels of slides. We used a Nikon dedicated slide scanner (CoolScan, I think). Went through all of them in about a weekend.
Justin
Re: With illumination picture
Mike Rubes, Apex, NC
>Hi Bill,
That's very, very clever!!! My wife has about 85 cartons of slides from when she was a kid and this would be a neat idea to try to convert them.
Thanks!
Mike
Russ Fairfield
>It depends on how much money you want to spend, and how many slides you want to throw away.
When I wanted to copy all of the old slides a couple years ago, the cost was $2.50 to $3 per slide to have it done commercially. HP sells a 35mm slide scan adapter that can be used on most of their flat-bed scanners that cost about $30 at the time. The quality isn't as good as the commercial service, and it does take time; but the difference in quality wasn't enough to make it worth the commercial price, and I could afford to save a lot more pictures.
Others may have a different view.
Chuck Taylor
>There are companies that will do the scanning for you. Search online for "slide scanning" or "digitize transparencies". Prices seem to start at about 24 cents each.
Mike Hamilton
>Wonderful idea. I have a bunch of my father's slides and would love to do this for my mother. A question related to how often you have to unload to the computer - is there a resolution beyond which you have reached overkill?
Regards,
Mike Hamilton
Plainfield, IN
Re: Since retiring my photo business.....
Jamie Donaldson
>...4 yrs. ago I have used the same (now antiquated!) Epson 3200 flatbed scanner to scan/print from my old negs, most of which are 645 format. It also does a serviceable job with 35mm, but today I would look at a newer model with Digital ICE (scratch/dust healing software)and still not be out a ton of money.
Bill Howatt
>I used the best resolution the camera would do since I am not short of disk space and you can always throw data away if there is too much. My camera only does JPG files, not the much larger RAW format, so the files were in the 2-3MB range.
For the uploading intervals, I had the slides in boxes or in carousels which I then moved the slides to small boxes after copying. I numbered each box and had a matching folder name (Box23 for example) on the computer so if necessary I could find the slide again without sorting through them all. I made slips of paper the size of a slide with numbers on them and when it came time to start another box I put the paper with that box number in and took its picture so I could easily tell where each box was in the picture files. I would copy about 100 slides and then take them to the computer and upload them.
After I had all the folders created and images stored in them with cryptic filenames I used Irfanview (free) to rename all the files in the folder. So for Box 25, the filenames were Box25_1, Box25_2, etc.
Irfanview will change all the names in the folder automatically.
I like to have descriptive names for all my slides even though it isn't necessary with my management program. I have learned that if something goes wrong with it or if you want to change programs it is so much easier with descriptive filenames.
I then went through the slides with Irfanview and cropped them to remove any traces of slide mount. It was quick using Irfanview's keyboard commands. I then added descriptive filenames and stored the files. I did not replace the Box25_1 portion of the filename but appended the descriptive part to it so I had names like Box13_5_FredJones. An advantage of leaving the Box13_5 part is that you can have several slides named FredJones and you won't get a "filename already exists" message since there is an unique Box and image number (Box13_5) in the filename.
The descriptive renaming went quite quickly and you would have to do it if you wished using other methods as well. The cropping was very fast once you got going.
The whole exercise does take some time and is a fair bit of work so make sure you backup you files as you go just in case there is a hardware failure of you accidently delete what you didn't want to delete.
Bill
DickL
>Thanks for the ideas everyone
Regards,
Dick
