Re: Cutting Corian
jwoodwright
>I cut loads of Corian. 3/4" is really tough and it's truly a case where you must let the blade cut at it's rate. You can't muscle it through.
I use at least a 40 tooth 7 1/4" Carbide tip blade on my Delta Contractors Saw. The more teeth, smoother the cut. I've used 60 teeth and they work. Why tear up a $60.00 blade when a $10 blade does a great job?
If you can wheel your saw outside, all the better. The Installation guys all wear breathing protection. The mess is great and it gets all over. I've found cutting some wood, after you do the Corian makes clean-up easier. The sawdust and Corian dust seem attracted to each other. This also cleans up your blade... John
