Shaker style knob
Shaker style knob
Shaker style knob
Joe in a Cleveland Suburb
>Hello.
I made my once-a-year trip over to my little Jet Mini to make a Shaker knob over the weekend for a little cabinet I just made.
Someday I hope to be able to make (little) things on my lathe but this past weekend I realized it had been a while since playing with it (the lathe) and really didn't know what to do.
I poured through some old FWW mags and found a couple articles that helped, and searched FWW site for some answers.
I took some 4/4 cherry stock, turned it kinda roundish, created a 3/8" tenon on one end, took it off the lathe and attached my Nova thingy to it and put the tenon into the Nova so I could work on the actual knob part.
I think I am on the right track but I am having a tough time getting a nice shape. It's not coming out the way my brain sees it...
I made up lots of blanks to practice with/on.
My question is does anybody know if there is an on-line video that walks you through making a simple knob?
Thanks.
Joe
(turning lurker in a Cleveland suburb near Doug...)
Re: Shaker style knob
Allen Neighbors
>Joe, I don't know if there's a video or not, but if I were you, I'd make a small screw chuck, with the same size screw you plan on using to mount the knob. Then I'd mount the small blank on that screw chuck, and turn the knob. When you finish it, all you do is unscrew it, and mount it on the cabinet.
As far as the shape is concerned... look at some different knobs, and pick the shape you like, then practice on making it. :)
robo hippy
>The first thing I ever turned was a Shaker style mushroom drawer pull. I cut the head off a screw, chucked it up in the drill press, used a block of wood for a tool rest, and a bench chisel to turn with. This type mounted with a screw, not a tenon. Now, when I do some, I will turn at least 4 to make sure that I get a pair that match pretty closly. Don't worry if they don't match perfectly, and try several different designs. You can also look through books on Shaker furniture which will show different designs.
robo hippy
>cabinet knobs were also the first things I turned. I used a handdrill that I bolted to the workbench with a cut off screw stuck in the jaws. Screwed the wood onto that and used a sharpened screwdriver to shape it. I'm an advocate of using cutting tools but a good sharp scraper is really easy to use and get the shape right.
Re: Shaker style knob *LINK*
Marty - St. John's, Newfoundland, Canada
>Here is a link to Youtube for a video on turning a winestopper which is just a larger version of a drawer pull.
Hope this helps.
Marty
( remove the 99 for email )
http://www.youtube.com/watch?v=ocLsdXTTDdU
Thanks for the responses.
