Allen wrench chisel
Bob Macgregor
>In the past I have seen mention of using allen wrenches as chisels. Are there pictures of the way these should be ground? Is this a good tool to use to undercut loose rings?
BOB
Allen wrench chisel
Bob Macgregor
BOB
In a word, sure...
steve antonucci
>Grind the top of the key flat about 1/2 way through, and then a bevel angle on the bottom half. Drill a hole in some wood smaller than the key and put a drop of CA before jamming the key in the hole. assembly time: 5 min.
Keys are so hard, they take a good edge and cut like mad...
Steven
Re: Allen wrench chisel
Brian Hahn in SW Wisconsin
>Here is a picture of my Allen wrench tools. I don't do captive rings, but people around here use old dental tools that have been sharpened to get behind the ring.
George Van
>Thanks for the idea of what to do with the old keyless chucks I have accumulated from old rechargable drills Brian!
Bob Macgregor
>Thanks. Last weekend I made a mounting bar with different-sized holes in each end and set screws to hold the home-made bits. Next I'll make a handle, also with set screws, to hold the reversible bar. Allen wrenches seem to breed in my workbench drawers, so it will be nice to put some of them to use now that I have a better idea of how to make them into cutting tools.
