Is Chinese Chestnut good to turn?
Dominic Greco in Richboro PA
>Hi everyone,
And yes, I still use my lathe for wood turning! :>)
A co worker dropped off several large chunks of Cherry and some Chinese Chestnut this past Sunday. The cherry I have no problem with. But the chestnut is another issue. I have no experience with this wood and was wondering how it turned. Anyone tried it yet?
See ya around,
Dominic
Re: Is Chinese Chestnut good to turn?
Rick Allen
>The Chinese Chestnut I turned is open grained wood with wide growth rings. The rings have a striking contrast between early and late season growth. The wood turned well sanded well and took finish well. The wood didn't hold fine detail very well, possibly because of the open grain. The Chinese Chestnut I turned would not be suitable for pyrography, because of the different density of early/late season growth.
The wood checked quickly in log form but was check free when rough turned, waxed and left to dry (much better than the cherry I have turned wet).
When the wood is dry it is light weight so a thicker walled bowl doesn't feel heavy.
I enjoyed turning Chinese Chestnut and the object turned have striking grain patterns. If you pay attention to the orientation of the growth rings (which I failed to do on several pieces) you can achieve some very striking visual effects from simple bowl shapes.
Is It Free?
Barry Turner
Steven Antonucci
all wood is good to turn...
steve antonucci
>just some of it is better than others, Dom!
If you have wood in hand, give 'er a spin! We should probably add a "Wood Library" to the right hand bar to go with the "Grinds Library"- and people could see what different woods look like turned...
Ellis?
Steven
similar to Am. Chestnut?
>If it's like American Chestnut, it may be worth turning. I turned some Chestnut for the first time just this morning and it seems to machine and sand nicely. I did have some minor tearout with a skew chisel on a long, thin shaft but honing the skew and slowing down a bit helped. I'm going to try a coat of sanding sealer before the final pass on the next one.
What I have is wormy and I think it will look great.
Re: all wood is good to turn...
gtwilkins
>A Wood Library is a great idea!
It wood be a valuable resource especially as we would be able to see how the same species, from different parts of North America varies and compare how climate, location, etc affect the wood.
WC wood library *LINK*
>There is a wood library here with good variety of pictures, although not of turned items. It's a little hard to find though - go to Woodfinder and click on Wood Library. I wish there was a direct link in the left menu, say under "Odds & Ends".
http://www.woodfinder.com/woods/chestnut.php
