Random Orbital Sanders, air-operated ??
Ed Moore in SW Virginia
>There was a lot of noise made a while back about an excellent air-operated random orbital sander. Was it a Grex? I can't remember the brand name. Help, please.
Thanks,
Ed
Re: Random Orbital Sanders, air-operated ??
Greg Burnard
>Ed, That probably was the Grex. It's a handy little unit. Greg
Grex... a handy little unit, that takes ...
Allen Neighbors
>a large air compressor to operate.
Re: Grex... a handy little unit, that takes ...
Lan Brady
>Allen,
I must have a different Grex 2" sander. I have a small compressor and can sand for 20 minutes without it kicking back on.
I do only use 45 psi. The box, the unit came in, said it used 2.2 cfm @ 90psi.
Is that the same machine? I like mine a lot. I bought it form Bruce Hoover at the Southern State Symposium 2 years ago after the Gathering at Terry's.
Lan
Allen Neighbors
>Lan, it must be different than the one I've used. I don't remember the size or specs on it, but I borrowed one from a friend, just to try to see if I wanted one. About 2 or 3 minutes after I started sanding, my compressor kicked on and didn't kick off 'til I quit.
I only had a little Cambell Hausfield at that time, but I just thought it took too much air to drive it.
I ended up with a Sioux electric angle drill.
Grex may have changed it since, or it could have been my old compressor, but that was my experience.
Stuart Johnson
>I have a Grex and a 25-30 gallon compressor, not sure but somewhere close to that. I also run it at around 45 lbs. and it will kick on after 3 or 4 minutes. When it does I just use the sander as a passive sander until the compressor cycles.
Re: Random Orbital Sanders, *LINK*
Juergen
>I bought a Grex unit to replace a Milwaukee offset drill which lost its bearings. I found it worked very well but it used a lot of air. With a 30 gal tank the compressor would kick in after about 2-3 minutes of use. As mentioned in another post I use it in passive mode until the compressor recovers.
I got tired of changing between 2" and 3" pads on the Grex. So when I found the unit linked below on sale for $19.95 at the local Harbor Freight it was a no brainer. This unit is a Random Orbital Sanders even though the description does not indicate so.
Pneumatic Random Orbital Sander
