Face Plates
Sean Troy
>Hey all, does anyone know of some good faceplates that don't cost an arm and a leg? I'm done with these home made ones I've been using. I'd like something better balanced. Thanks for any help, Sean
Face Plates
Sean Troy
Re: Face Plates
Carole Valentine
>Sean, don't know what chuck you use, but I like the steel faceplate rings that are held by the expanding dovetails on my Nova jaws.
Affordable Face Plates
Robert W
>Bill Noble is a turner and has been making faceplates for years. He sells welded faceplates, and will even true them in his machine shop if you would like.
Knowledgeable guy, and is also a bundle of information on building a vacuum system, including selling rebuilt vacuum pumps.
Robert
Re: Face Plates
Brian Hahn in SW Wisconsin
>My experience with face plates has been "you gets what you pays for".
I had to buy new face plates when I got my new lathe and went with the Oneway face plates from Packard Woodworks and Craft Supplies.
I also have the ring and hub system that Craft supplies sells. It's good small to medium sized items like jam chucks, but I don't use it for large or badly out of balance pieces.
A good faceplate is cheaper than a trip to the emergency room.
Re: Face Plates
Darryl
>Try Bill Huhlemeier seahorsecustfab@aol.com web site
members.aol.com/seahorsecustfab
706 334-4057
Great to deal with and excellent product. No affiliation got his reference from David Ellsworth..
Re: Face Plates
Rick Allen
>I can think of face plates "that don't cost an arm and a leg". When compared to the Oneway face plates they are a disappointment. The Oneway face plates "cost an arm and a leg".
You should have one face plate that gives you confidence. A 6" Oneway face plate is that confidence faceplate for me. I know that the face plate is going to run true, balanced, without any flex and there are enough holes for screws. This is a heavy duty faceplate.
For long term or production turning I use the reed system face plates. I like these because they are cheap and I can set partly turned wood aside with these face plates attached. The hub is separate from the face plate so the partly turned objects can be stacked. These are light to medium duty face plates.
I with Carole
Steven Kubien
>I really like the Nova faceplate rings. Someday I will pick up a really nice Oneway to try out but so far I haven't seen a reason to.
Steve
What do you use them for?
steve antonucci
>I have a few Don Pencil 3" faceplates for my Nova. I like them because if I screw up and hit them, they don't bust up my tooling.
I've spun some really big wood on them with no ill effects using some masonry screws. They will hold, and I can't imagine what you'd have to be doing to have the wood come off?
That being said, I also tend to rely more on my chuck than the faceplates these days. Given the choice between putting money into another chuck or more faceplates, I'd probably go chuck. I have most of my faceplaces "dedicated" to jigs these days, and I can't recall the last time I used one...
Steven
Speaking of chucks, Teknatool sale at Lee Valley *LINK*
Curly Smith
>"Prices are reduced up to 30% on all our Teknatool brand inventory of lathe chucks and jaw sets. The prices you see on our website are the discounted prices. All stock is new, but is limited in quantity."
Teknatool Scroll Chuck Inventory on Sale
Re: What do you use them for?
Stuart Johnson
>I have some of Bill Noble's face plates and while they do work okay the ones I have require a nylon washer to tighten properly. They are not used often. The 3" Don Pencil are good and I use them regularly but in my opinion the 3" steel One Way is the best. I use a morse taper chuck adapter in the tail stock to align segmented rings. It is aluminum and the Don Pencil ones seem to hang up. I think this has something to do with aluminum being scaled and the two scales try to interlock. This is not a problem with the steel.
With all of that being said I don't use a face plate unless I am doing a segmented piece. Instead I use a screw chuck and regular chuck.
Don Pencil's are the ones.
Allen Neighbors
Re: Face Plates
Jesper, Denmark
>I have a 3" General that came with the Lathe and a 4" Oneway plus another 6" General, which I never use.
The 4" Oneway gets used 99% of the time. Maybe it cost too much, but there - in ten years of use, it's paid it's due.
I think the old saying goes: "You can pay me now or you can pay me later." Money paid for quality usually comes back in spades.
Sean, I made two...
Allen Neighbors
>face plate rings that fit my SN2 50mm jaws... one for expansion and one for contraction.
I made them from the Aluminum Drive in an old VHS recorder, and turned the dovetails in the rings to fit my jaws, and then drilled holes for screws in them.
Both of them work like a charm. I would'nt use them for heavy work, but for light stuff they work great. I also have one of the Nova 50mm face plate rings. It will work on heavy stuff, and the good thing about the rings is you can remove them from the lathe and remount without any problems... just like a regular faceplate.
