Oneway 1640 Controls Modification
Allen Neighbors
>I turn from both sides of the lathe, and outboard. I'm always having to reach past the spinning piece to change RPM or turn it off, or I'm having to turn around behind me to reach the controls.
I wanted a remote switch, but it's only on and off... no speed pot. That great Oneway service dept was helpful when I asked about the difficulty of removing the control cable from the Pendant Arm.
So I did it. I can now move the Control Box and it's bracket to two different mounts that I attached to the lathe, and I can put it back on the Pendant Arm.
This pic shows it mounted to a bracket that is attached to the inside of the outer flange of the outboard bed extension.
Re: Oneway 1640 Controls Modification
Second pic shows bracket.
Allen Neighbors
>Made from 3/4" black pipe fittings.
Third pic - Cable re-routed
Allen Neighbors
>The cable has been re-routed through the Pendant Mount tubing.
No more reaching past the wood to speed it up or slow it down!!
turning from both sides?
>Allen,
What are the advantages of turning from the other side of the lathe? Is it to see the inside more easily when working on a bowl?
George Van
>Grrrrreat idea Allen! I will have to do the same on my 2436. the pendant arm is never in quite the right place as it is a compromise to access different turning positions on one arm. Did you disconnect the wires at the main panel and then reroute to your new moveable post?
Re: turning from both sides?
Allen Neighbors
>Not just to see better, it's just to get to use my other hand, I guess. I seem to make the cuts a little easier from there, and keep the handle of the gouge braced a little better. I have what is called a benign familial tremor, which seems to get a little worse as I age, and when I get the handle of the gouge away from my body support, I have less control.
I've even straddled the ways a few times to get real support when making a long reach across the toolrest. :)
Allen Neighbors
>George, I sent you an email. I didn't touch the main panel. All the work was done in the Contol Box on the business end of the Pendant Arm.
I explained it in a little pdf file that I sent you. Hope it helps. It's the smartest thing I've done lately. Big safety move!
