Screwchuck for small objects.....
Jesper, Denmark
Jesper, Denmark
>Some time ago, we had a discussion about the best screwchuck for small items. My point was that they are easy to make. Having a busted knob on a kitchen door, I all of a sudden had the need....
Attached is apiece of Black Locust, 1/8" hole drilled all the way through to hold the screw. There is a tenon that fits in the #2 jaws on a Stronghold chuck.
Manufacturing time about 10 minutes.
The screw is a 3.5 mm metric, which is tight in the hole. The reason for the locust is that it really hangs on to the screw. The face of the chuck is slightly concave to get a good hold on the OD of the object base. There is a little drawback here, as you have to tighten the object if you reduce the foot diameter.
Re: Screwchuck for small objects.....
Allen Neighbors
>Jesper, that's a neat way to hold small items. We've got plenty of Black Locust around this place. Thanks for showing it. I've often wanted to put a small piece on the lathe, and didn't think of making a little screw-chuck for holding it. I always have used that little spearpoint that won't hold anything... the one that's called safety-something...
I'll remember this from now on. Thanks again.
Wally Dickerman in Arizona
>My first screwchuck was shopmade. In the early 80's I visited some of the myrtlewood turners on the Oregon Coast. They were all using screwchucks. They were made using a faceplate and a block of wood. A lagbolt was used. The head was recessed and epoxied in. The bolt was shortened and using a rattail file the threads were deepened and sharpened. They still use screwchucks today. If you buy a myrtlewood bowl you'll find a small label in the center of the bottom. It covers the screwhole.
After seeing theirs I went home and made a couple for myself.
Wally
