Air filtration system
elliott
>Any suggestions for a small system in a basement around 600 sq '
Re: Air filtration system
Dale Bright
>Yes, get a box fan and a 20X20 furnace filter of good quality. I have 2 in my shop, which is quite a bit bigger than yours, and they do a very good job along with my dust collector.
Allen Neighbors
>Elliot if you ask an airconditioning man, he'll probably have a squirrel cage that he's removed from someone's AC system, that he'll just give you.
I built my own that hangs above my lathe. I built a box around it, and made slots that AC filters slide into. The air is just circulated through four filters and around into the shop. It works really well.
If you have a low ceiling, you could make it into a rolling table that you can use for a workbench.
Ralph
>I've used the same system as Dale, it really does work. One of the woodworking publications tried it also, in a review of filter systems and were impressed.
In your case, a basement shop (had one, SWMBO hated it) do all you can to control dust.
IMO, the $$ you spend on an air filtration system is always going to be cheaper then $$$$$$ you spend on health care, after.
Today, I have spent the money on a quality SYSTEM.
I have a good (mobile) DC that I connect to each machine, as needed. I even have a hood that goes on the lathe (for sanding or dry blanks).
  • Plus I have a real air-filter, in my case it's the Delta AP-100.
  • Plus I have the face-mask/air-filter, in my case it's a Trend AirShield
  • Re: Air filtration system
    Carole Valentine
    >I have the JDS Air-Tech 750ER with the electrostatic filter. I am amazed at what it picks up even when I think I'm not creating a lot of dust!
    don lewonczyk
    >Go with Carole, the JDS 750 with the electrostatic filter which is washable. If you put it or any other filtration system in it helps to have something , small fan to help circulate the air towards the dust remover. Don't need it but it helps. The JDS will filter the air in your 600SQ FT shop 8 times an hour. My shop is 1200 sq ft and 12 ft high sidewalls and they do a decent job when I remember to turn them on. As the others told you , you can get by going the least expensive way but if you can afford it all you have to do is hang it out of the box and plug it in and put the batteries in the remote control and your in business. Don L
    elliott
    >Any feedback on the Jet 1000B model vs the JDL 750?
    elliott
    >Amazon has the JET for $204 vs JDL for $319 both with free shipping. but i don't knowif there is an electrostic filter available for the jet.
    Carole Valentine
    >Some folks feel like the electrostatic filter lets too much dust through vs the pleated filter. I have not tried the pleated filter because I like to be able to just wash the E-filter. Maybe I will and see if I see any difference on the inner bags. Seems to me there were a few folks having problems with the electronics on the Jet, but I don't know where I read that. The JDS moves a little more air than the Jet, or so they say. Who can you believe these days?
    Ditto the JDS System.
    Jennifer@Indy.USA
    Ed Larson
    >I just purchased the Jet ASF-100B three days ago from Woodcraft for $229 with no tax (They had a tax day sale). Used it today in the shop. Works great. The shop is !5 X 20 X 9.
