Do you have a document or tutorial on making hand mirrors? I remember your demo a few years back and can't remember if I took notes or you had a handout, but of course I can't find a thing when I want to try it myself. Did you use a chuck to hold the piece? Silicone to glue the mirror?
Also, did you ever turn one from chestnut? (If not, do you want to?) Someone gave me some 1" chestnut boards today and I'm looking for something thin to try making.
>John Sorry I didn't see this sooner. I've been rather busy this week. I have a handout that I pass out at demos but and I've written an article for Woodturning on making square mirrors but I don't have any of those on the computer.
Basically I mount use 4" jaws on the lathe. I mount a 3" square wasteblock on the good side of the mirror blank. I use CA and Accelerator so the block can be removed easily with a sharp blow of a hammer on a chisel.
Then I turn the opening or the glass + 1/8". I make is about twice the depth of the glass thickness. I undercut that opening to allow for wood movement. Then I turn the rest of the glass side of the mirror, sand and put a sealer coat on.
I remove the wasteblock and then expand the 4" jaws into the mirror opening and then turn the good side of the mirror blank.
If you don't have 4" jaws simply drill a hole in the center of the 3" square wasteblock. I use this hole to align the wasteblock with the center of the mirror blank but it also serves to align the wasteblock with another wasteblock screwed to the faceplate. I center drill this block and then put some CA glue on the blocks and align them using a short piece of dowel to fit in the holes. I don't glue the dowel in the holes so the wasteblocks are easy to seperate.
Using the non chuck method I turn the opening for the glass and then seperate the wasteblock from the mirror blank but leave it on the faceplace. I just barely knock off the corners of the square block so it fit perfectly in the opening you just turned for the glass. This aligns the mirror blank perfectly so you can turn the outside of the mirror. I use the square blank because you can get a chisel into one of the flat sides to pop it off the finished mirror. Again, I use CA and accelorator so the square block is easy to seperate from the mirror.
I drill the hole for the handle on the drill press using a sort of fence with a V block screwed to it. I have also done it using a table that fits in my tool rest banjo. Mount the dril in the headstock and use the tailstock to both align and push the mirror blank into the drill bit.
I use Clear Silicone Caulking to hold the glass onto the wood. Be sure to clean both surfaces with something like alcohol or Naptha to remove any oils in the wood or glass. The only failures I've had seem to be traceable to oil in the wood or not cleaning the glass. I only know of 2 failures the last 5 years but can't keep track of where my mirrors go.
If you need glass in any quantity I will gladly sell you some. I sell them at $2.50 each plus shipping. I just shipped 10 for $5 so shipping isn't too bad. It would only cost a little less to send 2 because I would have to buy the padded envelopes. I would guess maybe $2.50 to $3.
>Thanks! I do have 4" chuck jaws so I'll try that. I think I'll practice with pine or something before I try the chestnut.
I bought a dozen mirrors when a local craft store was going out of business. They were cheap at 50% off - I probably should have bought all of them!
I was impressed with your mirrors at the demo and have been meaning to try making one. Thanks for the instructions. (This is another thing we could illustrate simply and clearly with 3D graphics for the book "Make Cool Things on the Lathe Just Like Me" by John Lucas.
