Dust Collector
Dust Collector
Dust Collector
elliott
>Looking to find out what would be the most apprioate dust colector as far as HP, CFM for woodturning on the lathe
Re: Dust Collector
Re: Dust Collector
>Is this going to only for your lathe? If this is so, a 1 HP unit would work quite nicely (700 CFM). If you are going to collect dust from several tools, you would probably need a bigger unit (say 1.5 hp and 1100 CFM).
You need about 500-600 CFM to collect dust from a large "source", such as a jointer or planer. Figure that your ducting/hoses will "rob" some of the airflow.
Bill Pentz has an excellent site for reference. "Woodshop Dust Control" by Sandor Nagyszalanczy is a reasonable book to have.
Re: Dust Collector
Re: Dust Collector
>I have a 1 1/2 hp unit that is supposed to around 1200 CFM. I have it piped to most of the other tools in my shop and left a place I could add a pipe to the lathe, but never have run the pipe because I don't think you can do effective "chip" control for a lathe. Just too much wood flying in too many different directions. Nothing short of a tornado will catch them. Actually, I don't know that, because I have not tried, but that's my story and I am sticking to it. I do bring up a four inch hose and use it for dust collection when I am sanding, but that's a different problem than the shavings or chips.
I have found a problem though. During a recent episode of turning some very green wood I got some of those wonderful long stringy shavings. Made a huge mess I did. Used the DC with the four inch hose to vac them up. Later I realized the DC sounded funny so I pulled the inlet pipe off and looked in side. The strings had gotten caught on the vanes of the impeller and there was about a shoebox full of them riding around inside. Not good. Did not appear it would have cleared itself. I have a roll around trash can I converted to a separator so that the trash goes into the can, but not through the DC. I guess I will be using that in the future. My point to all this is that a cyclone would have worked better because the trash does not go through the impeller. OTOH, Cyclones cost a LOT more. Or, you could just walk on the strings for a month or two to dry them out and break them up and then use the DC.
Re: Dust Collector
Re: Dust Collector
elliott
>I have a 1HP harbor freight that sells for $99.00(small red one) I find that the suction doesn't do much at all, only for sanding and the hose has to be up close. I guess most turners don't use collection systems.
Re: Dust Collector
Re: Dust Collector
robo hippy
>I use a scoop shovel for the shavings, but then I can turn out 50 to 100 gallons a day from bowls. Oneida makes the best systems out there, and some are portable. You can make a cyclone your self without too much trouble, you can buy a plastic cyclone lid for a garbage can, or get one of the 2 stage systems. All you have to do is suck up one chunk of wood, and your impellor blades will be bent. They can be straightened out but never as good as new. If you have plastic impellor blades, they will break. The systems with a pleated paper filter, and a can for the shavings are the best, and cleanest. The bag systems work, but are more trouble to change out.
robo hippy
Re: Dust Collector
Re: Dust Collector
>Elliot, I have installed my system in a small shed or closet outside the wall of the shop, so the noise and dust are out side. If I could, I would take the bag off mine and just let it blow the crap out into the yard, but I live on a half acre in a subdivision.
I have made some changes in mine to improve the suction, but the best thing I found was I took the bag off and turned it inside out and shook it out. Got an astonishing amount of crap out of it. The suction improved dramatically. So, I should do that occasionally. Maybe you should check your bag for clogging.
If I had a cyclone, It might be good enough to eliminate the filters and just let the exhaust blow out side.
