Drill Press
elliott
>Looking to see which of the 2 drill presses would be best. Looking at the 10" sears craftsman and the 10" Harbor freight.
Drill Press
elliott
Re: If those are your two choices, go with Crafts.
>man. Friends don't let friends buy major tools from Harbor Freight.
Seriously though, you'd probably be happier with the Craftsman, such that it is. Does this press have enough power, quill travel, etc. for you? It is a small benchtop drill press.
Re: Drill Press
>I'd look at Grizzly. The probably have better service than either of the other two. If you need to buy it locally go to Lowes. Delta sells a small one that is pretty good.
Dumb question- What do you need a Drill Press for?
steve antonucci
>I honestly rarely use mine since I started turning. I think if I was making pens, I'd drill them on the lathe because it is much more accurate. The rest of my holes I drill by hand with a cordless.
The few times I use the drill press, I only use it because I have it. If I didn't, I wouldn't run out to buy one...
So what are you drilling?
Steven
Re: Dumb question- What do you need a Drill Press
Darryl
>Good question. I bought a Harbor Freight one many years ago. It has served me as well as can be expected. The main use I have for it is cutting out sanding disks from Industrial Abrasives 1ydX1meter cloth. I also purchased a cross slide vise for the table. I use it to assemble pens. Don't really have much more use for it other than holding dons the floor and holding up the vise. (I bought the floor model).
Obvious answer: drilling holes!
Brian Hahn in SW Wisconsin
>Some of my turnings require a fair amount of precision in the location of the axis points. A drill press is a lot more accurate than my hand drill.
I use it to drill the holes in bud vases and lamps. My vases can't be drilled while on the lathe because there is no way to hold them when the time finally comes to drill them.
