>Does anyone know what would be a good finish to apply over wood that has been bleached? It's been a long time since I've done any bleaching. I remember that I turned a couple of pieces then bleached them. I used no other finish. I saw one years later and I wasn't too happy with the way it had aged.
>Wally I've only ever done 1 piece I bleached and it was a maple goblet. I finished it with water based lacquer. It is clear and so far hasn't changed the color after 2 years.
Keith Newton, LR, Arkansas------WebKitFormBoundary
Guest
Re: Bleached Wood...
>Wally, I am not to sure that you will get much that you will like. When you bleach wood, the chemicals just leach all of the extractives out of the cells on the surface, leaving something akin to tissue on the surface.
When you wet that out with any finish, other than a pigment like in paint, it will likely destroy the bleached effect.
>I've bleached quite a bit of wood. I've used Lacquer, minwax wipe on poly, and just about every other finish I've played with over the years. No problems at all. I do not neutralize the bleach like it tells you to in the package. I've never had a problem. This wasn't intentional I just didn't have anything to neutralize it with one time and finished it anyway. I didn't see a problem so I just kept on skipping that step.
The only thing I've noticed with bleach is you have to wet the wood to find out what it will look like with the finish applied. Any finish will darken the bleached wood a little. The wood looks a lot lighter after the bleach dries than it will appear when wet so you have to apply several more coats if you want it that light.
My last two projects were the red and white box with the pyrography lines and the AED paddles on my Cardiac lamp. Both were bleached white. The box elder box took about 5 coats to get it white and the Cherry paddles took about 8 to 10 coats.
>I have just recently bleached several pieces. I used lacquer thinned about 50% with thinner. I let it soak in real well. Carole Valentine told me about it and she might have received the information from Russ.
The bleached color was unaffected by the thinned lacquer.
>I've bleached a few pieces and lacquer had the least effect on color in my attempts. I used spray on Deft from the can and it was only marginally darker than unfinished wood.
>Wally, I have bleached quite a number of pieces of maple to eggshell white,and to keep them that way, I use Minwax Polycrylic. (water-based). This seems to have the least effect on the "whiteness" of any of the water-based finishes. It looks like it is darkening the color when you first apply it, but when it dries, the white you had from the bleaching is back. Some other water based finished can give a pronounced cold blue cast to the wood.
Lacquer also works, but I do not like to vent my shop at -30% F.
>Krylon Fixatiff leaves the least color change of anything I've tried. Most of the time it looks like you didn't apply any finish at all. It is especially good on wire brushed or sandblasted surfaces since it doesn't appear that you did anything at all to the wood.
You can buff a Fixatiff finished surface with the Beal system but then it starts to change color, a little less than thinnned lacquer but definitely darker than no buffing at all.
>I was using bleaching "kits" until a chemist friend explained what they contained. Now I make my own "kit". It is simple. Go to a chemical supplies outlet. Buy a gallon of Caustic Soda (50% solution) and a gallon of hydrogen peroxide (35% solution). Get some distilled water and reduce both these concentrations to 10% solution and store in properly labeled storage containers designed for chemical storage you get from the chemical supplies outlet. Be careful -- these are dangerous chemicals and can burn you.
Then, when you want to bleach something, dampen it with the caustic soda, then dampen it with the peroxide. The soda causes the peroxide to break down, giving off oxygen and bleaching the wood.
Why go to all this bother when you can buy a kit. Cost. The two gallons of chemicals cost less than one pint "kit" and makes up into 3.5 gallons of peroxide and five gallons of caustic soda -- enough for a lifetime, or enough to share with your buddies for a long time.
