Wolverine Jig Knob Replacement?
Jerry Hall
>I have seen variations of replacements of the hard to grip brass knob on the Wolverine fingernail jig: Turned wood, plastic wing nuts, and other solutions.
Is there an easy way to get the brass knob off and reuse the locking bolt? Heat? Screw off, locking with a crescent wrench? Saw off and replace?
Thanks for any thoughts. My hands are having trouble locking it down.
I especially have a problem with my shortened Sorby bowl gouge where the flute end ramps against the spring and slides.
So thats another question, beside not buying another Sorby, it seems there could be a better design to avoid that slippage. I have been forced to learn to hand sharpen!
Re: Wolverine Jig Knob Replacement?
>Jerry Don Gieger sells an excellent replacement knob for the Wolverine.
his is for the Ellsworth jig-sorry
I had a broken plastic knob...
Clem Wixted
>... and I wrote to Kevin at Oneway. He said that a good replacement for the knob was a golf ball. Just drill an appropriate size hole in the ball and epoxy or CA it onto the head of the bolt.
I used a heat gun to remove the broken plastic knob.
Clem
Dick Hines
Re: I had a broken plastic knob...
Dick Hines
>I broke the plastic one np mine. I turned a knob and flouted it with a drumb sander and CA glued to to the post. It's been like that for 3 years.
Couple ideas...
Peter Teubel
>Leave the brass knob on. Turn a recess in a block of wood so the knob fits in snug. Then turn the rest of the wood to a knob/handle you desire. Then just epoxy it to the knob.
Concerning the short flute issue. Grind the top of your gouge flat to the level of the top of the flute. That flat will now allow the spring steel tab to index and hold the gouge in the jig.
Keep in mind that the last inch or so of the flute might not be hardened so you may need a new gouge soon anyway.
Re: Couple ideas...
Jerry Hall
>Great ideas, both. Thanks all. I am on my way to deal with both issues. Jerry
Doug Thompson near Cleveland
>Jerry, the brass knob is much better than the plastic of years ago. I had trouble when it was time to remove the tool from the jig... the hands would slip on the knob. So I used a thin cutoff wheel and cut a groove every 1/4 inch about a 1/8 deep around the diameter, problem solved ;)
keith zimmerman, Normal, IL
>When my plastic knob broke off, I go another plastic knob from Oneway, but it didn't fit! This was before the brass knobs were available. Anywaym I just use a hex wrench on my jig. It works..it ain't pretty...but it works.
keithz
>The large Vari-Grind has a socket head bolt, turn it clockwise to loosen and counter-clockwise to tighten. Drives me nuts... a left handed bolt would have solved this problem.
Your other question... *LINK*
Steven Kubien
>You've got lots of good ideas/solutions to the knob issue. As for the Oneway spring issue...
Craft Supplies sells the Tru-Grind system which is very similar to the Wolverine. The tool holder is slightly different in that there is no springy metal thingamabob. Instead, there is a bar perdendicular to the long axis of the gouge which clamps down on the flute via a thumb wheel. Simply back off the wheel and the bar raises allowing you to slide the gouge out without the flute rubbing (and dulling) against anything. Is that the sort of thing you are wondering about/looking for? Hope it helps.
Steve Kubien
Tru-grind holder at Craft Supplies
Re: Your other question...
Bill Neddow
>Lyle Jamieson highly recommends this solution to the problem.
Jerry Hall
>When the flute dies out it creates a slope, so there is a 1/2-3/4" or so of tool that slips as the jig is locked down, or worse yet when I am sharpening, mucking up my grind and scaring me besides. I messed with the tool protrusion, going to 1-1/2" to regain the flat of the flute, then skipping past the ramp by going to 2". Doesn't make any big difference in the grind, but I have to remember where I am to get a repeatable grind on that particular tool.
I will borrow a True Grind to see if the design is better in that respect, but I suspect it will slide as well since it seems it will clamp on the "ramp" too sooner or later.
As suggested by Peter I ground a 1/4" flat at the end of the flute, and it seems to have done the job until I finish off the Sorby. Nice simple fix, Peter.
I have just got a Thompson 5/8 Bowl Gouge, and it by comparison is very generous in tool and flute length, and is a great tool. No more Sorby's for me. Too expensive for too little value.
This of course is an infrequent, but not the less irritating problem. I very much appreciate the comments and ideas!
That's where I heard of it :)
Steven Kubien
michael serpa
>The McNaughton holder solves both problems!
