Homemade Lathe Light... Pipes?
Allen Neighbors
>Someone, not long ago, posted photos of their lathe light they had made from galvanized pipe, an adjustable arm hanging from the ceiling. I can't find the thread.
Does anyone remember who it was?
I'm going to build something tomorrow... I'm tired of having to move my lamps around when I'm turning different pieces, and I use both sides of my OW1640, so I can't use the one that fastens to the backside of the lathe. From above seems to be the only way to go.
Thanks, to anyone who remembers... :)
Re: Homemade Lathe Light... Pipes?
this one?  *LINK*
light by Gary in Zirconia,NC
That's it!!
Allen Neighbors
>Thanks, John... I guess I should have searched for "Lathe Lighting", huh? Didn't know how it was titled. Could only thing of Ceiling Light... Pipe Light... Adjustable Pipe Light... such stupid stuff...
Thanks for posting this for me.
Re: That's it!!
>I searched for various combinations of 'lathe galvanized light lighting pipe ceiling' and I forget what else before I hit the thread. Embarrassed to say I wasted some time searching in vain on the Messages forum and had to start over in Turning!
John, Your Light In the Same Thread...
Clem Wixted
>...for your Jet Mini lathe, uses a WalMart adjustable light. You mounted it on the corner of the lathe with threaded rod. My question is, did you just insert the lamp into the pipe that is over the threaded rod, or is the lamp fixed somehow in the pipe? If it just sits in the pipe does the lamp stay in position or does it move around from lathe vibration?
Thanks,
Clem
Re: John, Your Light In the Same Thread...
>Clem,
The lamp I use slips into the hole on the top of a tube fastened to the threaded rod. I don't have anything to hold it into place, but vibration has not been a problem for me. However, I have only used that lathe to turn wands - never something that might vibrate. If so, I would probably tack weld a nut on the side of the top of the tube (or simply drill and tap a hole) and use a thumbscrew of some sort to keep the light from moving. But it may not even be a problem. The tube is rigid on the lathe.
To fasten the threaded rod, I tapped the mounting hole already in the lathe - the hole was already the right size for the threaded rod I had on hand (3/8"). I hand thread the rod into the lathe then tighten a nut to lock it down firmly and hold the rod firmly. The tube I found (about 5/8" dia) almost fit over the nut, so I took a second nut and forced it up a ways into the end of the tube. (drawing attached) This way I could thread the pipe down over the rod by hand until it jammed with the lower nut and seated firmly, then slip the light into the top.
The only problem I had was the tailstock lock handle hit the tube in one position so that may need a redesign.
Also, the last time I checked, Walmart no longer carried the long swing-arm lights. They have a shorter-armed model with a weighted base which is fine for setting on a table but the arm may not be long enough to position it as desired over the lathe with this mounting. A variation of the galvanized pipe arm method might be useful here if I ever use this lathe again outside in the dark! I have some metal tubes with joints salvaged from a collapsible chair so I may try to use those somehow.
John, You're Great
Clem Wixted
>Not only are you articulate when describing things but also creative in your drawings and pictures. You make learning fun and meaningful.
Someone recently had some of your DVD's for sale and I missed getting them. I would like to absorb more knowledge from you. When I first started getting seriously into turning you had a demo scheduled in Memphis and I wasn't a member of the club and couldn't attend. I guess they were full. That may have been a blessing because I was self driven to gather all the knowledge I could without being a member of a club that was a 200 mile round trip to make meetings. Most of my knowledge is from this forum, and a few others, along with some books and videos. I did have a few short training sessions with some turners that were very helpful. John Lucas, Jeff Jilg, Darrell Feltmate and Chuck Ludwingsen are some of the others that have had a influence on my turning hobby. Practicing what I've learned is what is helping me to improve.
Although I have never told you, you (and a few others) have been a driving force for me in my pursuit of turning. You have provided helpful advice and encouragement even though it hasn't been directed specifically to me. I'm sure that you have done so for many others, as well. On my behalf, and their's, THANKS!
Clem
Ditto, Clem!
Allen Neighbors
>You said it well. Over 150miles round trip to a club, leaves us 'outbackers' to the forums. John, John, Darrell, Ken, Terry, and many more. Many, Many, Thanks!
woah, you got me confused with someone else!
>Clem,
I'm John K. Jordan. I've heard about another John Jordan who is a woodturner from further west in TN. He has woodturning DVDs and teaches and conducts seminars and sells hollow turned things for a lot of money. He's not me, although we are both the same age. Since I took up woodturning I've had a lot of confusion over my name but I've had it so long I'm not inclined to change it. I used to sign my name "not the other John Jordan" but I got tired of that.
I'm an amateur woodturner, retired from Oak Ridge National Lab, now raising goats and horses and driving the tractor around the farm. I have in fact made a number of DVDs but they are on subjects like Hybrid Solar Lighting and the Spallation Neutron Source. :)
During my career in software development at the Lab I wore out both of my wrists from typing too much so I taught myself 3D graphics and animation. Over the next 15 years or so I did a lot of scientific, technical, and architecture modeling and rendering so it's easy for me. All I use it for now is to illustrate an occasional woodturning thing, or to design a building or modification for myself or a friend.
I did see the other John Jordan post a message or two here recently but it seems rare. I guess he's pretty busy.
But truth be known, all John Jordans in the world are great guys! (At one time there were four John Jordans in our local phone book.)
I was only partially wrong :-(
Clem Wixted
>John,
My reference to the DVD's was apparently wrong. I was impressed that he would post such useful information here. I was wrong. You are the poster of useful information.
However, the rest of what I said about you is now even more meaningful. Now I'm not sorry I didn't get his DVD's :-) I also don't think I will be watching any of your DVD's anytime soon but I would imagine that in that field they are valuable.
I'm almost 68 and retired about 11 years ago from the printing industry from some senior management positions. I have about 10 acres in northeast Arkansas and a small tractor, have raised a pig (long story) and chickens. Now I mostly cut grass and do a lot of substitute teaching at a local Christian school. I do a little turning on one of my three wood lathes and cut up and collect a lot of free and found wood. I'm also playing around with some metal working with a mill/drill and a metal lathe.
I need to get some nice bib overalls like you :-)
Again, John, thanks for sharing and all of my original comments (except the DVD) still hold true.
Clem
Re: I was only partially wrong :-(
>Clem,
Thanks for the words of encouragement. I have a lot of fun learning and playing with wood and believe in trying to share as much as I can. The knowledge and experience here is incredible - I don't think I've ever logged in to WC without learning something.
There seem to be a lot of people these days interested in metal working. I do a lot of welding and "crude" metal working, but a lathe and mill are high on my wishlist.
BTW, if you followed the OJ Simpson farce on TV back when, you may have already watched some of my work. While it didn't make it to DVD, CBS ran a reinactment of the crime scene behind the news anchor during the trial coverage. I did the modeling and a homicide analyst/reconstruction expert friend of mind did the reinactment animation.
John, That's Impressive
Clem Wixted
>I don't remember that kind of detail but I remember in general what was done to illustrate the crime. It's a little different from woodturning but I imagine a creative mind could come up with some pretty gruesome detail about turning :-) Like the description of golf anf football that some comedians have done.
I've been out of town for a few days, without computer access, and that is a crime in itself! Tha's why my reply is late.
Good talking with you John and getting to know you better. When I get my mill/drill and lathe working well, and I do a few projects, I have a forge that needs some work and then it's into some blacksmithing.
Clem
Re: John, That's Impressive
>Clem we have too many hobbies. I also have a mill/drill that I'm working on. It basically just needs a good tune up and some cleaning. I also have a Forge that I plan to pull out this spring to work on some tool rests and possible start making the tools for metal spinning.
Forges
>I may have something for both of you some day. In anticipation of setting up my own forge, I've been collecting old things made from true wrought iron. (you can ID it by sparks from grinding)
Unfortunately, barring a medical miracle in the next few years I don't think my right shoulder, hand, and wrist will ever be up to the pounding needed. I have nearly abandoned my plans to set up for blacksmithing and may have some wrought iron pieces that someone could put to good use.
Steven Antonucci
Buy a pneumatic hammer?
steve antonucci
>I know it's a little bit like cheating, but it allows you to be a smith without the pounding.
I've been sort of considering a small forge myself, but I haven't got the space to build a small blacksmith shed. Getting an anvil would be cool, but they just aren't out there in my market for less than primo $$$.
I was turning today (picture in a seperate post) and I needed some metal working to make modifications to some tooling to be able to undercut and my hook tool. I broke my hook twice today trying to "tweak it" in a vise. At least I know it was hard. I've been using a MAPP torch to heat small sections of steel, but the minute I find an anvil...
Steven
Re: Buy a pneumatic hammer?
>>...but the minute I find an anvil...
My brother bought an anvil for me at Tractor Supply. It's an inexpensive Russian anvil, this one not quite large enough for general blacksmithing, but it has a nice ring to it.
Steven Antonucci
TSC... Never thought of that!
steve antonucci
>Passing one on Wed...
Anvil coming home with me if they have one...
Thanks
Steve
the one I have is about 100 lbs
>Northern Tool, Harbor Frieght, and others also sell anvils. I see Grizzly has a 300 lb anvil for $370 but I'd want to smack it with a hammer to see how live it was.
I also found one at a farm estate sale once but the guy in front of me had just bought it. A huge 500 pounder!
You might check your local Craigslist, but I usually see more "wanted to buy" than "for sale" and the anvils I have found are way too expensive.
>Having a seperate shed sure would be nice for metal working. I have to haul anything outside if I want to grind or forge. I'm too worried about fires. As a turner and flat woodworker I seem to have a lot of fire starter laying around, even though I keep my shop pretty clean.
You don't need a high quality anvil for the average beginner smithy (that would be me). A good anvil reduces the fatique and the corners,horn, and hardy hole are all better but it's kind of like buying your first lathe. There's no doubt you get what you pay for but you can do a lot of work with the cheaper model until you decide that your serious about you Blacksmithing and want to step up. I bought a 75 lb cheapy from HF and it's worked OK. I know I'll want a better one as soon as I can afford it but it's way better than nothing and has gotten me by so far.
A decent anvil is $300 and up. I haven't been able to find a used one that was worth the price they are asking. Most have considerable damage to the corners and top surface and I don't have the skill to resurface them yet. One guy tried to sell me what he said was a 300lb anvil. I asked him if I could have for $100 if I could carry it to my truck. (I know how to read the anvil weight and it was 165lbs). He wouldn't take my offer. It was pretty beat up and probably not worth $100.
Steven Antonucci
Can you post a picture?
steve antonucci
>i want to see how big a 100# anvil might be before I get too excited-
Steve
Re: Can you post a picture?
>I can't get a picture right now, but I measured it: 19" overall length, about 9" high, and the flat surface on the top is 4"x8".
Steven Antonucci
Thanks- bigger than I thought...
steve antonucci
>I'll see if the local TSC has one, and then I just need a big stump to mount it on. There is that willow just across the yard...
Steven
Bob Macgregor
>I'm still irked that somebody stole my antique Pennsylvania anvil...and its been 15 years!! I still have the chisel insert with the tapered square end, but the anvil is long gone; maybe I should get rid of the chisel so I won't be reminded of this sad occurrence? I hope the thief sprained his back, dented his pickup bed and dropped the iron on his foot, so there!
