Punky Pen Blanks
Punky Pen Blanks
Punky Pen Blanks
Christine
>I have some beautiful spalted maple pen blanks that are very punky/soft/light. Can anyone recommend a way for me to harden the wood? I tried turning a pen on one, and chunks came off it. Also, if you can suggest a method of hardning the wood, would I brush it on or soak it in the solution? Thanks.
Re: Punky Pen Blanks
Barry Elder
>There are those who say that life is too short to turn punky wood. However, some people brush the wood with thinned lacquer (thinned to help penetration), some use thin super glue (with proper safety precautions), Minwax makes a wood hardener, there is Pentacryl and Polycryl, soaking in a 50/50 mix of white glue and water, and various other ingenious solutions. Brushing or soaking is a choice that you will make. Check with the turning goods suppliers that you prefer and they all will make recommendations. Keep turning and learning! And good luck!
Steven Antonucci
Tough one.
steve antonucci
>There's spalted, then punky, and then "too far gone". I am one of those people who will put anything up on the lathe once. If chunks are coming off and you are using good technique, it may just be "too far gone".
Try soaking in CA on a scrap to see if it works for you. No sense in commiting to an entire blank's worth until you know if it will get you the finish you need. When sanding, be extra careful because the punky wood sands away pretty darn easily.
Steven
Wally Dickerman in Arizona
>I belong to the "life is too short to turn crappy wood" school. However, if you're intent on using the wood, I suggest that you try soaking the blanks in a solution of 50/50 white glue and water. I've done this successfully with wood that had some soft spots. (Even though it could have been called crappy wood)
Wally
Ken Oakley-Sunny St. Cloud, Fla
>I have a gentleman in New Jersey who buys lots of pen blanks from me on Ebay. One time I put a bunch of "Punky" blanks in the USPS Flat Rate box as a filler and told him if he couldn't use them to scrap them. He responded saying he would take all I could send him as he had bought a vacuum oven to stabilize the wood after applying some type of solution. He is happy and I get rid of all my rejects that way. Sometimes the punky wood has the best coloring and graining.
Gary Evans Tallassee, TN
>I save the mineral spirits that I use to clean poly off my brushes. I just keep adding coats till the soft wood won't soak up any more. As you turn your pen, if you find that you are turning past the penetration point of the solution, just put some more on. You could do the same thing with lacquer.
I just love to recycle. 8^]
Gary
Re: Punky Pen Blanks *LINK*
Dick Coers
>About a buck a blank at River Ridge for professional stabilizing. Great people, great product. The blank will almost be like plastic.
custom stabilizing
