Glue Question
Glue Question
Glue Question
Sean Troy
>Does anyone know of a glue that will permanently adhere a dry piece of wood (face grain) to a freshly cut piece of green wood (end grain) ? This is turning related. Thanks for any help, Sean
Re: Glue Question
Re: Glue Question
>Sean I'm not a polyeurethane glue fan, mostly because of the mess and expense. I can usually find a glue that works equally well and is less messy and cheaper. However in this case I think that is the glue to use. I would be a little concerned about wood movement as the wet wood drys but it will bond the two together.
Re: Glue Question
Re: Glue Question
Russ Fairfield
>Is there any you can get a few screws in there and have a good joint??
There is no glue that sticks well to a piece of fresh green wood because of the free water. Even if the wood was dry, the end-grain would make for a weak joint, and adding moisture is compounding the weakness of the joint.
Is this going to be a permanent joint? or a temporary joint such as a waste-block. There are ways to get a temporary joint. I don't know of anyway to make a permanent joint with wet wood.
If you let it sit for a few days until the free-water has evaporated out of the glue area, leaving only the bound-moisture, you MIGHT get a bond with Polyurethane glue, or Liquid Nails would be a better choice. I would never turn a piece with this glue joint as the only way of holding it on the lathe because it can never be trusted. Some people use CA glue here, but it is also a weak joint that can't be trusted.
The best bet is to use a hair dryer or heat gun on the wet wood, and get it as dry as possible on the surface. It helps if the free-water has had a chance to evaporate from the surface before heating. Then you can use either Titebond-2, a polyurethane glue, or an epoxy. BUT you will have only a couple days to turn the piece before the moisture migrates back to the surface and destroys the glue bond.
Re: Glue Question
Re: Glue Question
Sean Troy
>No screws as it will be turned. The joint is only temporary but needs to be fairly strong.
Re: Glue Question
Re: Glue Question
Ron in Drums PA
>Is the dry wood a waste block?
Re: Glue Question
Re: Glue Question
Sean Troy
>No, I'ts just to temporarly hold together two log halfs being turned. the tailstock against one site of the dry wood and drive center against the other.
Re: Glue Question
Re: Glue Question
Ron in Drums PA
>So the dry wood is sandwiched between the two logs?
How big are the logs?
Re: Glue Question
Keith Tompkins
Re: Glue Question
Keith Tompkins
>Sean, perhaps you can make plywood end caps that will allow screws (or lags)to be inserted into both the dry and the wet pieces. Allow extra length for trimming to length.
Re: Glue Question
Re: Glue Question
Sean Troy
>3M 5200 Marine Aheasive was recommended and looks as though that may do the trick. I would rather not use screws as I'll be doing some hollowing also.
Re: Glue Question
Re: Glue Question..... one other one
Ruth Niles
>Sean, the glass artists who use my flat-top stoppers use E6000, they get it at Michaels, A.C. Moore or art supply shops. They are gluing flat glass to flat stainless steel with no problem. You said you were going to be turning it rather quickly (not a few weeks, right?) so I'd bet that stuff would work for your needs.
Re: Glue Question
Sean Troy
>Thanks Ruth for the idea. I contacted the manufacturer for recommendations. Sean
