Orca Lathe
Jim Shewan
>Spotted this on Trade Me (New Zealand auction site)and wondered if anyone knew anything about these mini's. Its made of aluminium in Canada and appears to be a reasonable price.(buy now $170NZ)
Orca Lathe
Jim Shewan
Re: No Pic ET
ET
Re: Orca Lathe
ET
>Ok, never mind the pic, I found it on Trade Me, NZ. These little lathes were / are similar to the Bonnie Klein mini lathe. Some features are better and some are not as good. But I enjoy using the one that I have. It is accurate: the centres line up and drilling with the tailstock is right on line. A 1/2 in 3-jaw chuck can be directly threaded onto the tailstock ram. It is lots of fun to make small projects on this lathe; check out Bonnie Klein's videos for ideas for projects.
The Orca was orriginally priced at $350 can (no motor). Way over priced. A tool store was clearing out the last few for $150 can(no motor) a few years ago, and would have pobably taken less to see them out the door. They were introduced before the cast iron mini lathe came on the market (Jet, Delta, Mercury, etc). The belt is a 3 mm poly-v that is available from any bearing / belt supply that sells Gates products, and probably other belt mfgs as well.
Head stock spindle thread is 3/4 x 16 and takes a #1 morse taper. $100 nz, not too bad for a whole lot of fun. But be sure to haggle for a lower price. ET
Re: Orca Lathe
ET
>BTW, the bed extension was intended to be used under the headstock to make a "gap bed" so that a larger piece of wood could be turned. Excellent anodized aluminum faceplates are available from Don Pencil, or which retailer is selling his products in your area. ET
Re: Orca Lathe
Jim Shewan
>Thanks very much for the very detailed and helpful response ET. The asking price includes a motor but there doesn't seem to be a lot of interest so I'll keep in mind your advice regards price.
Re: Orca Lathe
gtwilkins
>I have Orca #7 and it a little gem for small projects, mine has a 6 speed pulley system. It is great fun to use especially at the kitchen table when my wife is out!. As mentioned it is very accurate and durable as the chap that gave it to me turned thousands of pens on it and it still looks brand new.
I would try and do a deal on it, hope this helps, Trevor
