Magnolia wood?
Magnolia wood?
Magnolia wood?
Mark Paulley
>Hello all!!!!!
Has anyone turned magnolia tree? I got some (very very green) and split it down the middle and found some great colors in the heart wood. After a short period the colors disappeared to various shades of brown but still nice looking. Just don't know if worth turning?
Any help or comments appreciated.
Mark
Re: Magnolia wood?
Re: Magnolia wood?
Tommy Holmes
>I've turned a few small pieces of magnolia and fouind it to be nice turning wood. The few pieces I've turned didn't have much color but still very much worth turning.
Re: Magnolia wood?
Re: Magnolia wood?
James McClure
>I turn a lot of magnolia and really like to use it in the bowl turning classes that I teach. When it's fresh, it usually cuts nicely and because it is fairly soft it works well for beginners. Use it as quickly as you can because it will start to turn gray (blue stain) either by rough turning and drying or finish turning. If you finish turn it when it is wet, it will move some, but not too dramatically. Sometimes it will spalt nicely, but usually it just turns gray and gets punky. When it gets to this state, I usually put it in the burn pile. Poplar is a member of the magnolia family so if you know anything about poplar, this wood is very similar.
Re: Magnolia wood?
Re: Magnolia wood?
Ron McKinley
>I've turned a few pieces and found that it doesn't have much color. The last bowl I turned showed a lot of grain but it was a dreary gray so I dyed it with a red dye. It didn't turn out as well as I hoped but I think with the right technique there are some possibilities......Ron
Re: Magnolia wood?
Magnolia Box
Ron McKinley
>This is one of the first boxes I made several years ago. You can see I didn't blend the curve near the bottom very well. This has a Watco Natural finish and has a green cast that will probably fade to a brownish cast with time......Ron
Re: Magnolia wood?
Re: Magnolia wood?
Bill Crommett
>Turns easily, but very bland.
Re: Magnolia wood?
Re: Magnolia wood?
Gary Evans Tallassee, TN
>It seems that the amount of color is related to the tree's maturity. Here is a picture of the wood from a 300 year old Magnolia out of New Orleans. The tree came down during Katrina.
Gary
Re: Magnolia wood?
Re: Magnolia wood?
Rick Pixley
>Let it spault and then turn it....I then dyed it and the spaulting figure really looks good..The trick is to no let it get "punky"..Rick
Re: Magnolia wood?
Re: Magnolia wood?------WebKitFormBoundarycEvbfnP2
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>I have turned a good deal of magnolia and love that wood. The magnolia I have turned was easy to work and has beautiful gray/blue streaks throughout. It does warp a bit if turned green, but very pretty. When I need a light colored wood, I reach for holly or magnolia.
------WebKitFormBoundarycEvbfnP2wgHy+xOX
------WebKitFormBoundaryamRDO1Q6ZrF+ZWlF
