Microwave drying any good?
Alan Tolchinsky
>Hi All, I'd like to hear from anybody with some success with this drying method. What is your method? Is it a good technique or do some bowls crack?
Re: Microwave drying any good?
Barry Elder
>I googled "microwave drying" and read about several different turners methods and then adapted their methods to what I wanted to do. That's the best advice I can give you. Yes, it works, within limits. Pay attention to the warnings about stinking up your wife's microwave and the warnings about fire!
Ralph
>I use it, while my sample size is not large enough to say for 100% certain. It works for me.
I dry all kinds of wood. Lately I've been taking some Apple pen blanks from damp to dry. I have a stack in the oven, run them for less then 1 min (full power) then let them rest an hour. Continue until weight change stops. Then I will let them sit and mellow for a week.
I also finish dry bowls. I either rough turn-and-bag (for about 2 months), then micro-wave (see above) dry. I also sometimes turn to final and microwave as above. While I have had not failures in the rough turn (or drying blanks), I have with this, but not many.
Interestingly, last winter I was cleaning out my back files and found a 15 year old FWW article on microwaving wood to dry it. It was funny as I don't remotely recall being interested in turning back then, let alone turning green and drying the wood.
Alan Tolchinsky
>Ralph, Can you tell me what you are using to measure the weight loss? It must be pretty accurate.
Alan Tolchinsky
>Barry, Thanks, I didn't think of googling that.
>Alan I don't dry often in the microwave but have done it with success on smaller bowls and box blanks. I just have a cheap microwave so I start with 30 seconds and let the wood cool completely between each cycle. As the wood gets dry you can run it longer and the cool times stay the same or slighty shorter.
Because my times are very short I'm always there to observe it for any possibility of fires. I did have one problem. It boiled a hidden sap pocket and burned a hole in the side of the vessel.
I haven't used it for drying rough turned bowls yet so I can't give you any advice on drying thick wood.
Thanks Ralph and John
Alan Tolchinsky
>I appreciate all the advise given here and will try to experiment. Thanks to all who gave advise.
>I've used the microwave oven to dry, not bowls, but blanks for magic wands, several at a time. I weigh carefully, write the weight on the blank, heat with a short cycle (enough to get the blanks fairly hot) let them cool for 20 minutes or so, then repeat. Quit when the weight change becomes small. This took a long time to get from dripping green to good-n-dry. I use a laboratory triple-beam balance to weigh, good to 0.1g.
I've read it's important not to get in a hurry and heat too much at one time or the wood can burn on the inside.
Alan Tolchinsky
>.1 gram is the accuracy of the digital scales. I guess that's not a lot of water.
Been there, done that
Brian Hahn in SW Wisconsin
>"I've read it's important not to get in a hurry and heat too much at one time or the wood can burn on the inside."
I did that with a cherry vase blank. It started spewing smoke from the inside. Made a mad, hot-potato dash for the door. The kitchen smelled like cherry smoke for a couple of days afterwards.
Re: Been there, done that
Thom Sayles
>I found a bunch of maple beside the road, asked for it and received it. I rough turned some, bagged it, waited and found that it all split. So I tried turning the green wet stuff to finial thinkness (1/8th inch) and microwaved it. Buckled and warped but didn't crack. Kinda looks organic. Better than cracked but not perfect.
I have my own microwave in the shop ($69). I blast it for 2 minutes full power, watch the steam roll off. I blast it again for 2 minutes intervals and waiting between. When it feels dry I sand it, off the lathe because it is no longer round. I will find out if they sell this summer when I hit the farmer's market.
Bill Crommett
>Take a clue from the commercial dry kilns, and control the moisture so that your drying does not create "case hardening". One of the demonstrators at an annual symposium showed how he used the Microwave by covering up most of the venting holes on the inside to prevent too much moisture loss. I have used his method on a dedicated microwave that we had on a boat several years ago. It has most of the vents covered, and I hit the "half strength" button for one minute and walk away for an hour or so until the wood cools. On small pieces I use the "Kiss test" and on the larger pieces I weigh and record.
Ken Oakley-Sunny St. Cloud, Fla
>I tried it once with some spalted,pecky Pecan pen blanks without realizing there still were some small critters inside the blanks until they came boiling out. Talk about a stink----
Alan Tolchinsky
>Glad to hear people are having some success with this. But watch out for the bugs.
Re: I like this method
Alan Tolchinsky
>Thanks Jerry, I think his site is awesome. What a talent.
