3/16" ball end mill as tip for hollowing rig
Craig Daymon
>I'm still thinking about those ball end mills that Dave Hout uses when making boxes. I checked Enco and noticed that they have them down to 1/8" in size. A 3/16" size is a perfect fit for the Jordan hollowing tools (and I think several others) and I'm thinking it might (still have to try) offer some advantages over the standard tip, possibly a smoother finish.
Opinions? (Please don't tell me about the Hunter tip, I already know about that.)
-Craig
Re: 3/16" ball end mill as tip for hollowing rig
>I haven't used one but I think the ones I saw used were about 3/8" or larger. I would be afraid 3/16" would break too easily. It would depend on whether you get HSS or carbide. The HSS might hold up pretty well. If it was me I would get the #1 hunter tool. It will cut just as clean and will easily install in your tool. The learning curve would be about the same.
Jim Pugh, Elyria, OH
>Keep in mind that the 3/16" ball end mill is the diameter. The one with two cutting edges would then provide a cutting surface of about 3/32". Unless you are doing really small delicate work suggest you look at a larger one say 5/16 or 3/8". Any larger than that and it might be a little grabby.
While most folks seem to see this tool demoed by Dave Hout, Mark St. Leger seems to be the one who first showed it's use.
If you buy one go for the HSS one vs solid carbide. You will never dull it enough to worry about sharpening it so cheaper is better in this case.
I have one and have used it a time or two but it isn't my go to tool for boxes/goblets or other end grain work.
Steven Antonucci
Buy one and try it.
steve antonucci
>They're only a couple of dollars. What have you got to lose? I've put everything under the sun into a boring bar (except an end mill), and some work better than expected, some don't. You won't know how they'll work for you until you try it.
Steven
Don Orr
>The hollowing rig I got used (very gently) had a 3/8" ball end mill with it. I had heard about them being used for hollowing and tried it and it works great. It's HSS with a Titanium Nitride coating and cuts like mad inside a hollow vessel. I have not tried it in a box yet. I also would be concerned that a 3/16" would be too small and prone to breaking. Might be worth a try though.
Craig Daymon
>I mentioned the 3/16" ball end mill because the Jordan tool takes that size. I guess I could easily take a rod of 3/4" and drill through it to make a boring bar that would accept 3/8". Though, I might pick up some 3/16" mills also just to try for a finish cut. (I'm talking about this for finish cutting the inside of a hollowform.) The larger mill and required bar would restrict its use in smaller hollowforms.
I'd be using it with my captured hollowing rig and laser set-up. Certainly sounds worth a try.
Thanks,
Craig
