>Well the Quack put 14 screws and 2 plates into my left wrist and then had the cheek to say no driving for 6 weeks and No turning until he is happy everything is as good as it is going to get. Maybe 12 months!!
I am right handed so perhaps it could be worse ... I was thinking about captive systems ... and possibly something like is fitted to metal lathes for moving the cutting bit ...
So apart from watching a lot of DVD's or reading every book ever printed anybody got any suggestions on what I am going to do in my little shed for the next 12 months (SWMBO would not take kindly to turning it into a Bar or other such distraction).
All ideas treated in the strictest confidence (Yeah Right) Prizes for the most outrageous and the most useful ideas, maybe!!
>The first person to suggest cleaning and tidying the shed will receive with my complements a box of hungry woodworms (a load more subtle than termites!!)
>DON'T rush the healing. It's not worth it. Taking time off can be a good thing. It refreshes your imagination. Do the book reading and DVD's. Take the time to build a website to show your work. Practice photographing your turnings.
>I would probably spend a lot of time at some of the big Malls watching the pretty young things spending the hard earned money given to them by their husbands, boyfriends, or significant other. Also I could go over too Daytona beach and watch the bikini clad spring breakers do their thing. Fantasies are good, aren't they?
>For in the shop: I've done a bunch of spindle turning with my right hand only, with skew and detail gouge. While this is for long thin spindles where my left hand is busy playing steady rest, so I see no reason why small spindles that don't need a steady rest could not be turned with the left hand even tied behind the back! ...finger tops, bottle stoppers, etc. (Hey, sounds like a good turning club challenge.)
If you want to try this and haven't, I hold the tool with my right hand up near the point, with the tool rest height adjusted such that the back end of the handle rests comfortably under my forearm. For small stubby turnings such as finger tops I chuck up a piece of wood about 6" or so long and from 1" to 2" in diameter. I turn two or three items from that piece of wood.
To prevent you from sinking into despair and setting up the wet bar, seems to me that SWMBO would be thrilled to help with two-handed chores like holding the wood while tightening the chuck. An enlightened spouse might even see the wisdom of purchasing an additional chuck or two as a investment into your sanity and the long-term solidarity of the paired relationship. (Hey, do I get a prize for that, or what?!)
I think I might get frustrated reading books on woodturning and getting inspired with no fulfillment. It might be a good time instead to read some non-turning books like Hoadley's "Understanding Wood" and "Identifying Wood". Excellent material.
For outside of the shop: Do you play the piano? When I broke my left wrist once (I am right handed), I spent a lot of time improvising with just one hand and perfecting the right hand part of some difficult pieces.
>Why should the loss of use of your left hand stop you from turning, there is Roger Foden in the UK who is a member of the Register of Professional Turners and he only has one arm?
(His website is down at the moment: http://www.wonderful-woods.co.uk/)
He also demonstrates so he should be a spur to your endeavours!
I have recently had a knee replaced and I understand the impatience to get back to turning again, while I couldn't stand (4 weeks) for long periods, I was making drawings of all the pieces I would LIKE to make and am now in the process of making some of them!
And/or, get a copy of "WoodTurner Pro", if you don't have one, and spend the down time learning how to use it and designing some future projects. It might also be a good opportunity to learn how to use a CAD program for other WW projects, if you don't already have one that you use, because they tend to have a steep learning curve and you'll have nothing but time, and maybe a puppy.
I wouldn't do anything in the shop because I know myself. I'd either:
- forget that my arm was hurt and continually re-injure it, thereby prolonging the healing process (and possibly doing additional permanent damage)
- overcompensate for the injury and end up hurting something else.
>Since the bar is out, how about a mini casino? Depending on how big your shop is, you can probably fit a couple of blackjack tables and maybe a poker machine or two in there. Hire a couple of college coeds to deal, put in a vending machine and a camera system to keep everyone honest and your set.
>I had a operation on my left hand for carpal tunnel which is a nothing compared to you. I was turning two weeks later then I had the right hand done and couldn't do nothing for a month.
I would think about a captive system for the tool itself. A special tool rest could be made from square stock with holes bored every 1-1/2 - 2 inches, a "T" shape adapter can be made and the tool can be slid into a bushing to create a pivot point.
>Challenge the orthopod's reasoning. Does he think you are going to use a cant hook to turn logs ? How does he expect you or someone else to button your shirt or pull up your pants? Does he know what "Turning " consist of ?
>I'm in the follow the doctor's instructions camp. By all means talk to him and question why such a long lay off from turning. Just remember you went to him for a reason and while he might not know what is involved with turning he has more than a few years of training.
Think of the damage you might do if you start turning spindles with just your right hand and without thinking reach up and grab the handle wheel with your left. Now what about using the capture bar system and you get a major catch and instinct causes you to lift your left arm in front of your face as the bowl comes loose.
>Be cool, Tim! Discussion with your Dr. makes a lot of sense. So does a gift of a pen or bowl so he can see exactly what you are addicted to. If you're a good boy, he will be more likely to turn you loose sooner! But it's your arm he's trying to put back together, safely.
