Winged Vessel turning
Randy G
>This past month we had Bruce Perry do a demo on winged vessels. His design was very flowing and interesting so I thought I'd give it a shot. Below is one I was lucky enough to end up with.
Randy G
Let's try again.
Randy G
From Another angle
Randy G
Amazing
Ron McKinley
>How'd You Do That? .......Ron
Supercool.......
Jesper, Denmark
>How many times did you smack your fingers?
way to go Randy!!
GaryG in MD
>That's very imaginative -- I've never seen one like it.
Well done! ...Gary
Ummm...WOW!
Steven Kubien
Stunning!!!
Tim Grenville-Cleave
>No other words needed
Re: Winged Vessel - That's very cool !
Ray Carson - Lawrenceville, NJ
>All done on the lathe? How?
I can sort see how you formed the vessel and surrounding area but the outer edges look free hand or something.
As Tim the Tool Man Taylor would say, "Uggghhh!" (grunt with a questionable tone in your voice)
Ray
Re: Winged Vessel turning
Randy G
>Thanks everyone for the compliments, I was super happy with it. (well almost, there is a problem you can see in the detail). But yes, it was all done on the lathe, I turned a lot of air making the wing portion.. and some un-natural angles turning in to the bottom of the vessel. Remember the whole thing was spinning, so I could come straight in like you normally would. But it was fun... and managed to not hit my fingers once. I think fear kept them out of the way fairly well.
Basics on turning it...
1. Mount between centers. Off centered in 2 axis, 3 axis should be somewhat level. You don't want to go into the wood too much with something like a screw chuck
2. From tail stock side, form the "bottom" of the wings and portion, allowing for a Chuck foot.
3. re-chuck and form the top sides of the curve following the same lines. Make sure you take in steps so you don't lose support.
For lines 2 and 3 your turning a lot of air.
4. as you get towards the "center" form the vessel. The better you define the bottom, the better it will turn out.
5. Sand, mostly with the lathe off..
6. Reverse chuck in a Jam chuck and turn the bottom, and sand, again with the lathe off.
So that's the basics... wasn't sure about sharing the process of someone elses creation.. so I kept it simple. Thanks
Lan Brady
>This is just too cool!!!
Great job, I really like it!
Lan
Lynn Edwards
>Randy
That is really cool!!! About what RPM did you turn that?
Randy G
>Hmm... I didn't actually watch the RPM's I more or less kept it at a speed that was slow enough I felt save it wasn't going to fly off and hit me or anything else, but fast enough I felt I was getting a good cut going. Very light cuts, but cutting...
Let's say I started around 4-500 and worked up to 800 maybe???
