turning tool cabinet
Clay Foster
>I got my turning tool cabinet finished, so now I don't have the visual clutter of tools hanging on the wall when they aren't being used. The cabinet is made from cedar elm, the same wood as the grinder cabinet.
Clay Foster
inside of cabinet
Clay Foster
>The rack the long tools are in is made from PVC pipe ripped in two lengthwise.
Re: turning tool cabinet
Randy G
>Beautiful Cabinet Clay, very nice job on it. Love the grain
Brian Hahn in SW Wisconsin
>That's another beautiful cabinet, Clay.
I'm afraid my tools wouldn't begin to fit in that cabinet. LOL
Hmm, how the heck...
>...do you keep that wall from getting splattered with sap and finish and other debris? Or is it just too new to have any of that stuff?
I'm wishing I had put a piece of Formica or something against my new wall when I built my shop. It's really a mess now.
Nice cabinet, Clay.
Ellis-I use a force field :)
Re: inside of cabinet
Carol - now in NC Nebraska
>What diameter PVC Pipe?
Lovely cabinet. Your "shop furniture" is nicer than my house furniture.
Just color me green.
Re: Ellis-I use a force field :)
bowlman
>Farce fields? We don't need no stinking farce fields!! Jedi turners (s)coff at farce fields. We just wave our hands and they open up to let us pass.
In your campaign to simplify
Carole Valentine
>Beautiful cabinet, Clay. Are these the all the tools you had left?? If so, that should tell us something! I take it you do all of your sharpening freehand. I don't see a Wolverine. Do you have any dust collection?
Re: Hmm, how the heck...
Clay Foster
>Ellis,
It's new construction. I'll put a piece of that white bath board on the wall. It's easy to clean, and you can make sketches and notes on it with dry erase markers.
Jennifer@Indy.USA
>Could this be any indication that I have spent about $3000 too much on turning tools and accessories?
Clay, I think this is Keep It Simple in it's truest form.
A beautiful cabinet to add to the others.
I need to have a yard sale.
Jen :)
Clay Foster
>2" ID. I made a sled out of scrap that I could screw the PVC pipe to so it could be ripped on the table saw straight and safe. Then I ripped a flat spot on each side of the pipe half so they could be glued together with PVC cement.
Re: In your campaign to simplify
Clay Foster
>Thanks, Carole. That's all the tools I need for the turning I do.
I grind freehand. When I learned to turn, there weren't any grinding jigs. You learned to do it freehand or you had dull tools. It's like any other aspect of turning - the more you do it, the better you get at it until you don't even have to think about it any more. I think one of the most important things is to be relaxed so you can make fluid movements.
Now that the drywall and painting is finished, installing a dust collection system will be the next project.
Clay Foster
>Thanks, Jennifer. All the different turning tools are just a vehicle for a sharp edge. I've seen Del Stubbs turn with a water pipe, a shovel, an axe, and a pocket knife.
Jennifer@Indy.USA
>So what you're saying is I did over spend a little bit? And here I had such high expectations for all those gadgets.
>Jen I guess I'll start calling myself a tool collector because Clay is obviously a turner and doesn't need the $3000 in tools that you and I have. If I call my self a tool collector then I should be able to buy some more with a clear conscience.
Clay Foster
>Or maybe it means here's your opportunity to buy that Sorby woodturning shovel you've been wanting.
Re: Hmm, simple solution.....
Jesper, Denmark
>For those of you with SWMBO's, there is bound to be a shower curtain that is replaced and can be used to receive the splatter. There is even a side benefit that SWMBO will think it too dirty after a while and decide that a rocade is in order. As the design doubtless is changed, it brings a fresh new color into the shop.
Auxiliary question: Do the female persuation of turners then have a HWMBO or (as I suspect) does it not work that way?
Russ Fairfield
>If you want to get down to basics and the minimum of tools, you can do it all with a skew chisel and a scraper. You can turn all spindles with the skew, and you can turn everything else with a domed scraper.
We use all of these other tools because they are a more convenient means for getting the cutting edge to the wood, and they make up for what we lack in turning skills. The more skilled we become as woodturners, the fewer tools we need. Clay is obviously a very skilled woodturner.
Clay Foster
>I'm not as complete a turner as many I know. I've just had a lot of experience in a few narrow ranges of turning. If I started exploring all that can be done on a lathe, I would own a panoply of turning devices.
When a lot of us began turning, we bought a lot more tools than we needed. I know I did.
How about a Jerry Glaser shovel. :)
Jennifer@Indy.USA
>Don't let him fool you Russ. He just can't find the other tools. He probably has a ton of them tossed on his storage room floor that's probably covered with sawdust and scraps of old sandpaper and dried up drywall mud. I'm sure it's a cluttered mess in there.
