>Garret Wade (standard denial of connection with commercial intities)has a face shield made of metal mesh with a clear plastic view port. One could lecture through the mesh while looking through the clear view port at the same time protecting the schnozz from sudden design changes. Item number 19R06.01 It also has the advantage of not fogging in the hot soggy summer. It is on sale now.
>Does anyone know if this shield meets ANSI Z87.1? If not it is just a feel good item and does not meet the impact requirements for proper protection. I cannot find anywhere in the item description that it Meets ANSI Z87.1 - that usually means it does not meet proper impact standards and is not a proper safety faceshield. I had looked at this in one of their catalogs and could not find a reference to it meeting ANSI impact requirements.
>I just ordered one. I wear a faceshield only when I'm really nervous about a piece of wood. I know I should but I just find them extremely uncomfortable and 90% of what I turn is small anyway It sits right above my head collecting dust and then you have to clean it each time you try to use it. I might actually wear this one. OSHA approved or not it's got to be better than not wearing one.
>Have any of the others that ordered one of these face shields received theirs?
Mine came a day or so ago and I am not impressed. The shield is shorter that my normal mask. As a result there is a wide open area in the bottom. A slight amount of pressure on the bottom edge causes the whole mask to come up and off. I might be wrong but I don't think this shield offers much protection for anything other than shavings.
I will be interested in hearing the opinions of others.
>... I was disappointed as well and would not have bought if I could have seen up close and personal beforehand. It has such a flimsy viewing screen, but I glued it in place with Plumbers Goop and now it works much better. I will use it during some of my demos which shower me with chips while trying to talk, and that was my intended need.
>face shield, but what I did to mine might help yours.
I was always getting shavings in my coveralls because I didn't zip it up all the way to the collar, and they'd work their way down the neck of my t-shirt... and though it's a full face shield, it was still just short enough that I'd have shavings in my shorts before the day was done.
So I taped a 6" wide piece of canvas tarpaulin material along the bottom of my shield. It extends below my collar opening enough that it keeps the shavings out. Wonderful!
>Thanks for the tip Allen. It isn't so much that the mask is too short but that it is way to light weight to be of much use for anything other than light shavings.
>I was surprised the wire mesh was so flexible, what looked like a great idea was a let down. Live and learn... now we know. A face shield needs to take a hit but this won't.
>Stihl sells a "Forestry Helmet System" combining hard hat, mesh face shield, and hearing protection. I think it runs about $45 and is really substantial. Wearing it for a demo might look like overkill but it would provide the desired protection without muffling your talk. Link below, there's also a page of testimonials with photos of misadventures......
>I'll return it. If it came anywhere near to being safe I would keep it and chalk it up to a risk of doing sight unseen web ordering. As it is, I feel it is worse than not wearing anything because it might give a false sense of security.
