Pen Drilling Vise & Assembly
elliott
>Has anyone made a home version or is it better to suck up and buy one. I seem to have problem drilling straight
elliott
Re: Pen Drilling Vise & Assembly
eaglesc
>I fail to understand why t here is a need to purchase expensive gizmos to use on a tool so the tool can do what it was designed to do.
For the most part a drill press is used to drill a hole perpendicular to the table.(unless one wants a hole on a different axis in relation to the blank).
Before you go out to buy an unneeded device check a few things out.
Is the DP table perpendicular to the bit in the chuck?
No matter how much you pay for something to hold the blank if the table isn't "square" to the bit the resulting hole will not be centered.
If you are using a vee block and the table is sqaure to the bit, is the blank square?
It is not absolutely necessary to have perfectly square blanks for most materials but if the blank is tapered the hole will be parallel to the sides.
All that being said, all you need is a "V" block in a DP vice.
If you are doing production work a self centering vice is a big plus but not for a few blanks not necessary.
Because of the patterned blanks I make I need to drill dead center to the pattern not the blank.
Using a collet chuck on the lathe is the most accurate way I have found to drill center.
Sam Scalzo
>I made a vise from a wooden clamp. Make a notch in the center of the clamp to hold the wood. Drill table must be square to drill bit allway around. Hope this is clear. Sam
eaglesc
>There is another method that exempl;ifies the KISS technique.
I saw this along time ago, after I made my "V" block.
Stand 2 pieces of 2X4 stock and hinge together on the end grain.
Clamp shut and drill where the two abut with a 1/2 inch bit.
Mark the table where the 2x's lay when you drill them.
The result will be a "block that is already custom drilled to compensate for any irregularities of the table versus the Quill.
Excellent idea!
Peter Teubel
>Never would have thought of that. Thanks for the tip!
