Ball end mill on a stick for boxes?
Craig Daymon
>I was watching a Woodturning episode from the DIY channel today and David Hout was using a ball end mill (1/4" maybe, maybe bigger?) in the end of about a 3/4" rod to clean up the bottom of a lidded contain they were making. Anyone else ever try this? What size end mill do you use? What is the orientation of the end mill when cutting? They mentioned turning it slowly once inside to start cutting, but never showed what that orientation was.
This looks like an easy tool to make, should it be useful. Might even be good for hollowing in general?
In the episode, they referred to it as a "french curve scraper". I HOPE (after 13 stitches and nerve damage) that this never leads anyone to use a french curve scraper inside such a turning. Otherwise, it's a good chance they will relive my experience. A ball end mill on the end of a stick IS NOT a french curve scraper!
-Craig
Re: Ball end mill on a stick for boxes?
Steven Antonucci
It's a hook tool essentially...
steve antonucci
>The flute in the mill cuts like a small radius gouge, which can be much more easily had with a hook tool. Check out Andre Martel's website to see his hook, and you should be able to find some tutorials on how to make your own (I make them from short O1 steel scraps). You'll be amazed at how well they cut.
Steven
Gordon Seto
>1/4" and 3/8" would work. I use two-flute single end all carbide. 5/8" long bolt, cut off the hex end and hold in the chuck to drill a hole at the cut end for the ball end mill. I just use epoxy to glue the end mill in. The threaded end of the bolt will be epoxied into the wood handle. This tool is used with quite a bit of over hang over the tool rest, you will need a long handle for leverage.
I just push the tip in at the dead center, it is self drilling. Rotate the end of one of the spiral at around 9 o'clock and pull towards myself. It would cut curls. It has two flutes, I mark one side with a marker for rough cuts and reserve the other side for final pass.
Gordon
Mark Wollschlager
>I have seen Mark St. Leger use one to hollow boxes and have tried and used it myself.
A 3/8 single end ball end mill will fit in the Don Pencil scorpion bar.
I put that bar into either the Pencil arm brace or in a Kelton handle.
It cuts very smooth. It was not expensive, check enco for sales.
Just another way, not a bunch better.
Mark.
Thanks for the feedback
Craig Daymon
