Re: Does larger chuck mean less vibration?
Greg Haugen
>Vibration can be cause by a few things, the biggest are usually tool angle/presentation to the piece/grind and support. Speed can play a role but not as much as the others. Most often it's a dull tool/improper angle or poor support. You can produce vibration by rubbing or in this case pushing on the bevel too hard or having the wrong grind for that particular application.
As far as chucks go, it's debateable, about the large or small chuck question. What is fact, as previously, stated are the jaws. In my opinion, a Small chuck with large jaws is just as good as a large chuck with regular or medium jaws.
Another factor, for bowls at least, is the "quality" of the tenon. If the tenon isn't properly made, there's no flat "seat" section at the tenons's base where the top of the jaws are in FULL contact with the bowl that can cause vibration. Under the force of the gouge can actually be pushed out of "true" while cutting without a proper tenon.
I'd look at alot of the factors and if needed different jaws before I drop the money on a new chuck.
Greg H.
