Lathe is doing something abnormal! Help?
Mark Williamson
>While in the shop doing a bit of turning this evening, my lathe started doing something odd. The headstock seems to be jumping back and forth? I will be turning and all of a sudden, the workpiece wil jump toward the tailstock and back again. I have a Jet mini lathe and was using a nova chuck atthe time. At first it seemed like the chuck had come unscrewed a little but then I notice that the whole thing was moving? Has anyone experienced this before and am I getting ready to have a lathe meltdown or something? The thing is only like two or three years old?
Thanks for any input!
Mark
Re: Lathe is doing something abnormal! Help?
John Veerkamp
>Mark, Turn your lathe off and check your headstock shaft for endplay. Sounds like to me that your bearings are going south. Bearings aren't too hard or expensive to replace if done before ancillary damage happens to the shaft.
John
>Sounds to me like your handwheel has come loose. Loosen the setscrews and screw the handwheel on until there isn't any slop in the headstock spindle. Don't screw it on tight enough to bind up the movement, it should still rotate freely. Once you get all the slop out tighten the setscrew. I drilled my handwheel out tapped the hole and put in a second setscrew 90 degrees to the first one. Mine has not come loose since doing that.
Bill Hale / The Wood Spinner
>J.L.
Are you saying the handwheel holds the spindle in place ?
Bill in CG. AZ.
>Yes the handwheel holds the spindle in place and also provides the proper backlash adjustment for that lathe.
