Pen Making Jigs
elliott
>Does any one have pictures of pen drilling jigs and assembly jigs they made?
Pen Making Jigs
elliott
Re: Pen Making Jigs
Stuart Johnson
>Go over to youtube and do a search using rockler. They have a pen turning video and show a drill press jig. I don't know if this is the jig in the earlier posts but it looks like it would be easy to build.
Re: Pen Making Jigs
Mike Brazeau
>If you have spigot jaws for your chuck it is extremely easy to drill blanks on the lathe. A carpenter's vice works well for fitting together. No jigs required.
Re: Pen Making Jigs
Larry Gottlieb
>I have tried several jigs for drilling blanks and now use a self centering vise mounted on my drill press.
For assembling pens, my woodworking vise works well.
Larry
Re: Pen Making Jigs
Sam Scalzo
>I use a pen centering vise. Purchased it at Woodcraft. Before that I use a wood clamp with a slot cut into both sides to hold the wood. It works just fine. I also use a drill press to press the parts together. One other way is to purchase a bearing press at a use tool store or used equipment shop. I purchased one for $20.00. SAM
Re: Pen Making Jigs
Steven Kubien
>For assembly I turned a pair of morse-tapers-with-a-block-on-the-end (sorry for the technical terminology) which go into my headstock and tailstock. I use use these to press things together. As for drilling, mostly on the lathe...sometimes on the drill press.
Steve Kubien
