>Being new to turning I don't have a lot of experience and have gotten a lot of useful information from this site so I wanted to share a hopefully unique solution to a sanding problem. I have been using strips of progressively finer paper to sand the bowls and stoppers I am turning. My problem was that the friction would cause heat and make it uncomfortable to hold the paper to the wood. My solution was to use an old pair of neoprene hunting gloves that provide insulation from the heat but still allow me to have a lot of dexterity. Since the neoprene will compress a bit it helps me to keep good contact with the rounded shapes. Hope this helps.
>If you are getting that much heat, then there are two things that you can do to correct that. One, turn the speed down (for bowls, 500 rpm or less), and two apply less pressure. Slower speeds do remove stock and tool marks as fast or faster than higher speeds without the heat. Pushing too hard also generates more heat. Heat can cause fine cracks in the wood.
>Glenn, I used to generate a lot of heat when sanding, and learned on this forum that I was causing the little cracks that came into otherwise good solid wood. But now, I too, still wear gloves when sanding. But it's because I need the grip on my inertia sanders. I use those cloth gloves with the little rubber dots on them.
I also slowed down the rpm on my sanding, but still bounce between sanding slow and sanding fast, depending on the wood and piece. If I use a higher speed, I try to put less pressure on the sandpaper.
Thanks for posting. This is the place to learn different techniques, and you'll choose what's right for you.
>I have found that I get the best results when I can hold my bare hand on what ever I am sanding and not burn my hand. If you can't hold your hand on the piece while spinning you are going to fast.
>I agree with what others have said - if it gets hot while sanding there is too much speed or too much pressure, or both. I've read this advice from trusted resources and experienced it myself.
Another thing - if not careful, sanding primarily while the wood is spinning round and round can lead to hard-to-remove concentric sanding scratches visible in the final work. I've seen so many pieces which had these scratches and I think they detract considerably from the piece. A few of these pieces were by people who also commented how much the hate to sand. Hmmm...
I know one very likable but unfortunate fellow who has what I consider a good eye for form and a dose of creativity to go with it but almost every piece he shows has obvious concentric scratches. (I am beginning to wonder if he has eyesight issues, an entirely different problem.)
I've learned to do most of my sanding with the lathe turned off. I may sand by hand or by power with the lathe running, then turn off the lathe and rotate by hand, sanding usually with the next finer grit following the grain or figure (not always the same!) This makes it easy to see when the scratches from the previous operation are gone. If scratches are difficult to remove, I drop back and remove them with the coarser grit.
