REAL MILK PAINT
Grinding wheels
Grinding wheels
Grinding wheels
Bruce in Saint John, N.B.
>I'm about to treat my pedestal grinder to a couple of new grinding
wheels. I would be interested to know if anyone out there has used the wheels that Oneway sell. If so what did you think of them? How do they compare to the white aluminum oxide wheels? Thanks in advance.
Re: Grinding wheels
Re: Grinding wheels
Steve Worcester
>I have used Oneway's wheels since their intro. Good product, replaced the worn out ones with the same. They wear well and work well. Not a lot of load up.
The closest you will find are the Ruby wheels or Norton's SG. All god products for our purpose. A world of difference from White wheels.
Re: Grinding wheels
Re: Grinding wheels
Dave Peebles Lyons, Ohio!
>Hi Bruce,
I replaced my white wheels with the Oneway wheels a few months ago. I could not be more pleased. The loading is quite a bit less and they seem to run really cool.
I was very tempted to go with the Norton SG wheels, but just could not justify the cost. I am not sure if the Nortons are better at a $100.00 a piece, but I am really happy with the Oneway wheels. They do a great job for me.
Best wishes,
Dave
Re: Grinding wheels
Re: Grinding wheels
Greg Haugen
>Ok, time for a "shameless" plug for a WC advertiser. Check out the following link. http://www.sharpeningsupplies.com/Norton-C25.aspx It directly goes to the Sharpeningsupplies.com "Norton" page. There are two different Norton 3X wheels listed, one is an "I" hardness that most agree is a bit soft for us. Then lower on the page is a "K" hardness which is what everyone is raving about. They do also carry white AO wheels. The Norton 3X wheel proforms identically to the Oneway and SG wheels. Woodturning suppliers sell them for $100 each, Sharpening Supplies.com sells them for $45.97. Get a set for under $100. I have dealt with Sharpening Supplies and they're great people, excellent service, fast shipping, and they support WC! It's a win-win situation.
Just my two cents.
Greg H.
Re: Grinding wheels
Re: Grinding wheels
Steve Russell
>Hello,
I have eight grinders in my studio - two 8" Baldors, one 8" Jet and one 6" no-name, plus four Tormek wet grinders currently. In my last purchase, I opted for a set of the Norton SG wheels for my slow speed 8" Baldor grinder. The other dry grinders have either white Oneway wheels, pink, ruby, tan or blue SG's.
As the others have pointed out, the Oneway wheels are very good, but the Norton SG wheels are better in my experience. Yes, the SG's are expensive at a C-note each, but they work amazingly well for dry sharpening HSS turning tools. If I had to buy again and had a thick wallet, I would get the Norton SG's as they are clearly better in my experience using them side by side vs. the Oneway wheels.
It's like a beauty contest to some extent... All of the contestants are beautiful, but only one can win the crown. All of the optimized wheels for dry grinding - White, Pink, Ruby, Tan and Blue SG will work well for you, but the better quality wheels will resist loading on the face of the wheel longer, as well as maintain their shape better to reduce uneven wear patterns. Better wheels cost more, but there is a reason for that and in this case, the more expensive wheels really are better in use.
Having said that, I used standard el-cheapo white AO wheels for five years when I first opened my production studio and they worked fine. I did have to clean and dress them more frequently than the newer wheels I now use, but they worked just fine and cost about 1/3 the price of some of the wheels I now use. I think it's far more important to learn how to sharpen correctly (for most turners that means learning how to use a jig system) and to drag yourself kicking and screaming into the habit of sharpening frequently, than to rack your brains about the wheels. Good luck to you and best wishes in all of your woodturning endeavors!
P.S. I just wish choosing an espresso machine were as easy as getting a grinding wheel... :-o Any barista woodturners out there?
Steve Russell
The Woodlands, Texas
Re: Grinding wheels
Re: Grinding wheels and (OT) expresso machines
Claudia Hayward
>I stopped using a white wheel because it wore down really quickly and needed very frequent dressing. I replaced it with a Oneway wheel and find that it is a big improvement! And as for expresso machines, I just bought a new one. The salesman warned me to stay away from the offshore stuff (China and Romania) and get one that is built in Italy. A pump driven one is a must, as is a removable water reservoir. I bought a Saeco, low end but it seems to do a fine job.
Re: Grinding wheels
Re: Grinding wheels
robo hippy
>The longest lasting wheels out there are CBN. This is a grinding material made for grinding steel. It is 3/16 inch of material bonded onto an aluminum disc (no balancing required). My 80 grit wheel is 3 years old and still has over 1/8 inch of material left. You can't dress them, but clean them with a stick of hard white aluminum oxide. Any grinding supply place can get them for you or even make them for you. I know 3M is getting into them. You can get them made in any grit you want. I had a 320 wheel, and it wore out in about a year. I replaced that with a 150 grit wheel, and it is wearing much better. Cost is about $300 for an 8 by 1 inch wheel.
robo hippy
Re: Grinding wheels
Re: Grinding wheels
Rich Egan
>I just recently purchased a Norton 3X wheel, and I'm very impressed with it. It gets my tools so much sharper than the stock white wheel.
Re: Grinding wheels
Re: Grinding wheels
ThomD
>"The loading is quite a bit less and they seem to run really cool."
I wonder if this stuff isn't getting a little out of hand. I would rather they heated up a bit than threw mountains of powdered glass all over the shop. I don't have dust extraction at my wheels, and I probably use the same white ones most of us do. As far as fast is concerned, or cool, belt sanders are much superior but I have a feel for the wheel, and can't entirely toss them as yet.
Re: Grinding wheels
Re: Espresso!
Steve Worcester
>I bought a rebuilt Saeco superautomatic at Frys for $199 on sale! Had it for about a year now. Keep it filled with water and beans and just push a button. As an Americano freak, I do appreciate a good pull. And no work.
Re: Grinding wheels
grinding wheel color *LINK*
>Information from several sources warns against using color to judge the properties of any grinding wheel. One such example from Wood Tech, reprinted in the WoodWeb Knowledge Base:
"Grinding Wheels 101 - The are a number of different color wheels on the market today: this is not indicative of wheel quality. For example: there are blue colored wheels using conventional blue Aluminum Oxide grain and other blue wheels made with a more expensive Ceramic grain."
https://www.woodtechtooling.com/Grinding_Wheels/gr
Re: Grinding wheels
Re: grinding wheel color
Carol - now in NC Nebraska
>Hmmm....
Sounds like one could color-coordinate their shop... :)
