Re: Starter Lathe Suggestions
Fog Tanner
>I have a Delta 16" steel bed lathe. I have used it for turning bowls and making boxes. For bowls, I also used it with a McNaughton coring system as well. I made bowls close to the capacity with no problems.But, I now have a Vicmarc 300VL along with the Delta. I only had two complaints with the Delta, one being the legs. I like the base on my Vic and will eventually made one like that for my Delta. I have the Asussie version of the Vic and it is the easiest base I have ever worked around.
I got interested in off center turning and 16" was not enough swing. The Delta did handle the stress I put on it with the Escouleon chuck, so I have no complaints about that. But, I will never have another sliding headstock lathe, except for maybe a Robust.
They all have the same basic locking mechanism and it will come unlocked. I had mine unlock during the coring operations and it wasn't very nice. It doesn't have an emergency bar like my Vic, so turning the lathe off with headstock moving around while holding a tool gets interesting. That's why I looked at the Vicmarc and Oneway, eventually buying the Vicmarc. It is a 1000lbs of lathe and will do anything I want having 51" between centers. So far, I have made several 22"-23" bowls which is pushing the 23 1/2" swing but it handled them with no problem. And I just finished up a cute little 2" box and a hand full of 15/16" washers.
There is no perfect lathe, you just have to ask what you really want to do in turning. If it were strictly bowls, then a Stubby or a Vega. For just boxes, all you need is a Vicmarc 100. Of the sliding headstock lathes, Robust is the best. The locking mechanism on it is the largest of that type and its well made. Plus it is made in Occupied USA.
