Re: Heavy Metal
mfoster
>Thanks all for the nice comments. Most of the wood I got from this tree (which had recently given up the ghost) were flattish pieces that I salvaged from the trunk, which was already hollow, so I was left with what was left holding the tree up. This piece is 12" in diam. and 5" high.
There is no real mystery with the dovetail keys. I tried to come up with a way to machine the recesses, but anything I could come up with was not worth the trouble of designing and setting up a router jig. I finally decided that the Shakers probably did it by eye with hand tools, so that's what I did. I cut out 1/2" thick keys using the bandsaw, and cleaned them up some by sanding. I then held the keys against the inside of the bowl where I wanted them, and carefully traced them. You have to do this on the inside because holding them steady and accurately tracing the key (where the ends would be standing away from the outside of the bowl) would be extremely difficult and not nearly as accurate. From there it was a matter of patiently removing the wood and fitting the key. I used a combination of fret saws, drills and dremel/foredom tools to remove the bulk of the wood. Once it is roughed out, I took greater pains with how I oriented the tools I used. I find rotary tools work best in my hands for this. I used burrs with straight sides (typhoon and small carbide cylindrical burrs). The walls were about 3/16" thick, so it does not take a long bur to clean the sides. Keeping the tools oriented parallel is the real challenge. I continually check the outside with the key to make sure that the outside does not get too large. I start the process on the inside and work it till the key fits into what I have hollowed, and just keep going, constantly watchin the opposite side to make sure my tools are oriented parallel.
The results are OK but not as tight as I would expect on flatwork using a router template. I used liquid hide glue to glue them in. It is a darker color, and helps to hide the small inaccuracies. Once the glue is set, I hog off the bulk of the key with a large typhoon bur, and then it is a matter of sanding a bowl as per usual.
I know everyone was hoping for some cool jig, but they it seemed faster to me to just creep up on it. It took me an hour or two per key. Thankfully, I don't make a living doing this.
Mike
