skewchigouge?
skewchigouge?
skewchigouge?
Scott Hurley in N. VA
>Has anybody used a skewchigouge? Do they really work as advertised? How would you sharpen one - it obviously won't clamp into a Wolverine jig. Thanks.
Scott
Re: skewchigouge?
Re: skewchigouge?
Gordon Seto
>I have not used this tool. I watched the short video on Woodcraft. I suspect I heard chattering when Scott Phillips did the cove.
This is a Swiss army knife approach. It is not the best knife nor the best screw driver. I am not going to replace the skews and spindle gouges with this do it all gadget, I don't see the reason to own this.
Gordon
Re: skewchigouge?
Is this the same as a Bedan?
Allen Neighbors
>I sharpen my Bedan by hand on the grinder. Then hone with a diamond gizmo.
Re: skewchigouge?
Re: Is this the same as a Bedan?
John Veerkamp
>A bedan is square in profile and a skewgouge is round in profile. I made one and sharpened it by holding it flat on the grinder using a standard support. Having said that I didn't find it all that useful and converted it to a three sided point tool.
John
Re: skewchigouge?
Re: Is this the same as a Bedan? No.
Greg Haugen
>Bedans are often Trapezoidal in shape, the top is wider than the base, usually. They're ground flat across the front in the same nature of a parting tool or a beading/parting tool.
Skewchigouges are round bar stock with a fingernail grind and a flatten top. Eli Avisera also uses a similar tool.
For rolling beads nothing does a better job than a skew, or spindle gouge, or a beading/parting tool. For "V" cuts, you can't beat a skew. For coves, spindle gouges all the way.
There is no "do it all" tool. The only "do it all" way is to practice proper tool usage, and practice, practice, practice, and then when you get it, practice some more.
Just my two cents,
Greg
Re: skewchigouge?
Re: skewchigouge?
Doug Turner
>Yes. I made one from 1/4" HSS and use it for enlarging end grain small diameter holes, small coves etc. It is very forgiving in situations that might cause a catch with a small gouge. I use the wolverine tool to grind the bevel and then just touch up the flat top edge with a small diamond hone. The bevel does not need to be reground each sharpening. I also made a 1/2 diameter from a shock absorber shaft- I don't use it as frequently.
Re: skewchigouge?
Mike Stafford
Re: skewchigouge?
Mike Stafford
>I made a couple from drill rod. I sharpened the top flat by hand but I do sharpen the bottom bevel using the Vari-grind jig. See the picture...
Re: skewchigouge?
Thanks!
>Thanks for the quick replies. From what everybody's said, I don't think I'll bother to invest in one.
Scott
Re: skewchigouge?
Re: Thanks!
Ron in Drums PA
>Take a closer looks at Mike's. It's made from 1/4" HSS, The cost is around $2 bucks and a wood blank. Great Tool.
Re: skewchigouge?
They can be useful sometimes
Ken Grunke from SW WI
>I like mine, it looks just like Mike's but maybe with a keener bevel. There are times when nothing else will do, like when turning an inside/out ornament and you're afraid of a catch with the skew!
Re: skewchigouge?
Jesper, Denmark
Re: They can be useful sometimes
Jesper, Denmark
>Yep, when you ahve skared the Dickens out of yourself with everyting else, it will get those last few cuts done anyway.
Got one, don't use it often, but when I don'tdare use anything else....
Re: skewchigouge?
Re: Useful for Young Tunrners
Steve in NC
>I find that they are useful when teaching new turners. You can get the feel for riding the bevel without the likelyhood of a catch.
Steve
Re: skewchigouge?
Re: skewchigouge?
>I bought one and I didn't like it. Maybe I didn't give it enough time.
Re: skewchigouge?
save your money
robert davis
