Finish after leather dye
keith zimmerman, Normal IL
>I just finished applying black leather dye to a piece and the color is very flat. I want to add some sheen to the highest parts of the piece and was thinking about buffing it. Should I seal the piece first? What should I use?
Thanks in advance.
keithz
Re: Finish after leather dye
Allen Neighbors
>Keith, I've only used Leather Dye once. After it cured, I used my Lacquer Wash on it. Then buffed. It looked good.
Mike Brazeau
>I used a few coats of Waterlox on a Honey Locust Bowl that I had partially dyed with USMC Black and a candlestick of maple that I dyed black, which I believe I just waxed and buffed. Both turned out well. Nice satin finish on the candlestick and shiney on the bowl. If you wipe on the finish, you will get some ruboff. Have wanted to try that technique with some cherry and let the wood peak through, but it sits on the list of dream projects!
Cyril Griesbach
>Keith, my last (read only) experiment with leather dye on a piece was:
I gave it a couple coats of Danish Oil and when I buffed it some of the dye came off and the wood "blushed" through. By that I mean that the dye was not completely removed but the surface was thinned such that at certain angles I could see the color of the wood through the dye. Surprisingly this didn't occur on a sharper edge at the rim. Perhaps I was less agressive in the buffing in this area...I'm not sure. (It is a small plate/platter/shallow bowl.) I think I'm going to try some lacquer on it just to see what results I get. I'd be very interested in your process(s) and result(s).
Black shoe polish for an easy shine.
Brian Hahn in SW Wisconsin
Ron McKinley
>A coat of Danish oil, rubbed out well after the dye has dried. Let that dry overnight and buff and wax.......Ron
