question about polymer clay
bowlman
>Does anyone know if polymer clay can be turned after it is cooked in the oven?
bowlman
Re: question about polymer clay
Cyril Griesbach
>Dick, my friend, I hesitate to even try to imagine what you might be up to now. But I sure am anxious to find out.
Marvin Ewing
>A friend of mine turns beautiful pens out of polymer clay. He tells me that he mixes colors together and rolls them into the shape of pen tubes. I don't know much about the process but the finished results are beautiful. He even mixes goldleaf into the clay and sometimes brass shavings.
Marvin
bowlman
>Could you please find out if he turns them before baking or after baking? Thanks in advance.
dick gerard
just a wiiillllddd and craaazzzzyyyyy bowlmaker!!!!!!!!!!!
bowlman
>Well, depending on the answers I get, you may have a chance to see soon enough. Like I said, it depends. Till then, I'll just await some more definitive info.
Ken Grunke from SW WI
>I've played with the stuff before, it's just a plastic after baking but I don't think it has a lot of structural strength. I'm sure it could be turned, sanded, & polished like any plastic. There's different types of polymer clay, Fimo is more flexible after baking while Sculpy is harder and breaks easily. There's a gal in my area who makes cutesy lapel pins & such and I thought about enlisting her to make some decorative little buttons for inserting into turnings but haven't got 'round tuit yet.
HeatherA in AK
>There was this post a few weeks ago. Scroll down to a bowl with a polymer collar on a bowl.
Heather
ww.svwoodturners.org/SVWFeaturedPiece.html
Richard Allen
>The stuff turns fine. It is a bit flexible. On of the issues with the stuff is how thick you can bake. Much over 1/2" thick isn't going to bake very well. If you have a very precise oven with excellent temperature control (along with a good deal of experience) you can bake stuff maybe 1" thick.
I have turned kaleidoscopes, boxes and small bowls. You can turn before baking but the flexibility of the "stuff" is going to give you poor results.
I turned the stuff over 5 years ago. I know that polymer clay is changing and improving all the time. So maybe baking the stuff thicker than I was able to bake can be done now.
Robert Henderson
>I have heard that polyner clay pens are prone to cracking over time.
Has your friend had any problems of that sort?
Re: question about polymer clay *LINK*
Cory in MN
>There is a section in Kip Christensen and Rex Burningham's book, "Turning Pens and Pencils", that discusses turning polymer clay. It seems to work fine for pens...
You may want to check your local public library. I know ours has a couple copies of it.
Larry Gottlieb
>I have used polymer clay to make bands in pens. I form a disc, bake them, sand the flat sides, drill the proper size hole and glue them to the wood and brass tubes with polyurethane glue.
They turn and finish well. I don't know how well they last with use.
Larry
Ed Davidson (Colorado Springs)
>Yes, that is 100% do-able...light cuts and wet sand, after baking.
Emblems
Al Kapocius
>Been a'thinking to lay out emblems and such by building up the pattern from extruded strings, sorta like the millefoil stuff in glass. Should be easy enough to cut off built up sections like coins with a wire, something like a cheese cutter.
Also, was an article in the Woodturning Design magazine a while back about kneading and forming two colors of polymer clay, baking and turning a pen.
Methinks it might be a lot easier to roll out and combine a couple of thin layers, bake and set them on a diagonal in a pen blank. Think red, white and blue for a patriotic pen.
Al Kapocius
