Need help. And I may beed more.
henthorn
>I got my lathe table set up today. I had hoped to build a new one a little better than the old and a little more useful, but that isn't going to happen for a while.
I also got the lathe out of the box and on the table. I was sure panting after that as I still get breathless after very minimal effort. I started hooking it up and couldn't find the picture I had made of the hook up. I think L and N are the power terminals but I am not positive.
I may have fried the controller but am hoping that it was just a loose terminal. I sure am not functioning like I used to, but at last I am functioning......I think.
Glad I have a place where I can spout off once in while.
Re: Need help. And I may beed more.
Cyril Griesbach
>I can't really help you but others may be able to if you provide more information like the make and model of the lathe and maybe even the controller.
>Don,
I believe "L" is "Line Voltage" meaning the hot black wire, and "N" is for "Neutral" meaning the white wire. You should also have a terminal for "G" or green for ground.
mm
Thanks, to all
henthorn
>I finally figured it out but I made a stupid mistake in the cave I am using for a shop and fried the controller. I won't even say what I did. I need to find out if most any treadmill motor controller will work with my motor. I'm working on it.
Re: Thanks, to all - PM'ed back to you
Carol - now in NC Nebraska
>with the info you asked for.
PM me with what you did and what happened so I can include it in the info I am gathering for others who might want to do this down the road.
Thanks.
